Possible Values for PST/SST/AST
This section lists the possible values for the primary state (PST), secondary state (SST), and associated state (AST) shown in the output of the Report Status (rept-stat-) commands.
PST
Primary state possible values are the following:
- IS-ANR
- (IN SERVICE - ABNORMAL) The entity is in service but only able to perform a limited subset of its normal service functions.
- IS-NR
- (IN SERVICE - NORMAL) The entity is in service and handling all its normal service functions.
- OOS-MA
- (OUT OF SERVICE - MEMORY ADMINISTRATION) The entity is out of service because it has not been equipped.
- OOS-MT
- (OUT OF SERVICE - MAINTENANCE) The entity is out of service and is not available to perform its normal service function. The maintenance system is actively working to restore the entity to service.
- OOS-MT-DSBLD
- (OUT OF SERVICE - MAINTENANCE - DISABLED) The entity is out of service and the maintenance system is preventing the entity from performing its normal service function.
SST
Secondary state possible values are the following:
- Active
- (ACTIVE) The entity is currently in use and is handling its normal service function as the primary service provider. (MASTER) The entity is currently in a master state in relation to its redundant unit.
- Allowed
- (ALLOWED) The entity is handling its normal service function.
- Avail
- (AVAILABLE) Entity service is available to another entity.
- Blocked
- (BLOCKED) The entity has been manually prohibited from handling traffic.
- Busy
- (BUSY) The entity is handling the maximum traffic capacity and has no spare capacity for new service requests.
- Conn
- (CONNECT) The card’s entity status is in connected state.
- DDL Hunt
- (DDL HUNTING) The entity is currently in a state where the DDL is hunting for crossload info.
- DDL Inhib
- (DDL INHIBITED) The entity is currently in a state where the DDL is inhibited from crossload.
- DDL NoXld
- (DDL Unable to XLOAD) The entity is currently in a state where the DDL is unable to crossload.
- DDLunstb
- (DDL UNSTABLE) The entity is currently in DDL unstable state.
- Disc
- (Disconnect) The card’s entity status is in disconnected state.
- Fault
- (FAULT) The entity has failed.
- Idle
- (IDLE) The entity is in use and has spare capacity for service.
- Inhibited
- (INHIBITED) The entity has been manually prevented from performing its normal service function.
- Isolated
- (ISOLATED) The entity cannot be detected through software or hardware.
- LPBK
- (LOOPBACK) The entity is currently in the Loopback state.
- Manual
- (MANUAL) The entity has manually been removed from service and is not carrying any traffic.
- MEA
- (Matintenance Equipment Administration) The entity has been auto-inhibited and has been restricted from functioning because it has not met the minimum hardware requirements for the current configuration.
- MPS Unavl
- (MPS unavailable). MPS is required, but unavailable for the entity.
- Ovflw-1
- (OVERFLOW) One entity cannot provide service to another entity due to service denial.
- Prohibit
- (PROHIBITED) The entity is not handling traffic because of a failure in the network.
- Proh-Blk
- (PROHIBITED and BLOCKED) The entity has been prohibited and blocked from handling traffic.
- Restart
- (RESTART) The entity is in MTP Restart.
- Restrict
- (RESTRICTED) Normal operation for the entity is restricted. The normal capacity or configuration is not being used because of a failure in the network. The normal capacity, functionality or configuration of an entity may be restricted during loading or synching of data. This can occur when the Measurements Platform has not yet been enabled.
- Standby
- (STANDBY) The entity is currently in use and is handling its normal service function as an alternate service provider if the primary service provider failed. (SLAVE) The entity is currently in a slave state in relation to its redundant unit.
- Test
- (TEST) The entity is currently in a test state.
- Unavail
- (UNAVAILABLE) Entity service is unavailable to another entity.
- Ueq
- (UNEQUIPPED) The entity is not equipped.
- Unblocked
- (UNBLOCKED) The entity is handling its normal service function.
AST
Associated state possible values are the following:
- (BLANK) The field may be left blank.
- ACCESS
- (ACCESSIBLE) Traffic is being carried between the local entity and an adjacent, or remote, service provider. A full connection has been completed.
- ALMINH
- (ALARM INH) The alarms on the entity are inhibited.
- BRDG MSTR
- (MASTER) The E1/T1 channel bridge is in Master mode.
- BRDG SLAVE
- (SLAVE) The E1/T1 channel bridge is in Slave mode when the adjacent odd-numbered channel bridge is provisioned in Master mode.
- CDL
- (COMMAND DRIVEN LOOPBACK) The entity is in command driven loopback state.
- DB DIFF
- (DATABASE DIFFERENT) The entity has a database difference.
- ENET FLT
- (ETHERNET FAULT) An Ethernet fault exists.
- EXT BERT
- (EXTENDED BERT TEST) The entity is undergoing Extended BERT.
- FE LINE
- (FAR END LINE LOOPBACK) The entity is in far end line loopback.
- FE PAYLD
- (FAR END PAYLOAD LOOPBACK) The entity is in far end payload loopback.
- FLT CHK
- (FAULT ISOLATION TEST) The entity is undergoing a fault isolation test.
- INACCESS
- (INACCESSIBLE) Traffic is not being carried from the local entity to another service provider. A breakdown in a complete circuit has been detected.
- LFS
- (LINK FAULT SECTIONALIZATION) The entity is in Link Fault State.
- LINE
- (LINE LOOPBACK) The entitty is in line loopback state.
- LOCAL
- (LOCAL) The entity has become locally isolated.
- LXVR
- (LXVR LOOPBACK) The entity is in local transceiver loopback state.
- M BIP ERR
- (MOTHERBOARD IDENTITY PROM) The entity has a motherboard prom error.
- NOT BRDGD
- (NOT BRIDGED) The E1/T1 port channel is not bridged.
- OAM F5 FM
- (OAM LOOPBACK) The entity is in OAM initiated loopback state.
- PAYLOAD
- (PAYLOAD LOOPBACK) The entity is in payload loopback state.
- SLTM
- (SPECIAL MAINTENANCE TEST MESSAGES) The entity is in SLTM testing state.
