2 General Description
This document defines the step-by-step actions performed to execute a software upgrade of an in-service EAGLE® STP from the source release to the target release.
Figure 2-1 Upgrade Process
The following table lists the steps required to successfully complete the upgrade process.
Table 2-1 Upgrade Tasks to be Completed
| Upgrade Process Task | Date completed | Reference |
| Hardware Inventory | ||
| Hardware Ordered | ||
| New Hardware received | ||
| System Health Check #1 performed. | [1] | |
| System Health Check #1 output verified | ||
| Target Release Baseline Hardware installed | ||
| Target Software Release download (via Electronic Software Distribution or Upgrade Media). | [Appendix B.1.] | |
| System Health Check #2 performed. | [1] | |
| Enter Upgrade Software Access Key | [Appendix C] | |
| Configure Network Conversion Method. | [Appendix B.2] | |
| System Health Check #2 verified | ||
| Software Upgrade Session 1 completed | ||
| Health Check #3 performed. | [1] | |
| Software Upgrade Session 2 completed |
During the software upgrade execution, phase flags are displayed in the output messages to indicate upgrade progress. The output messages shown in this document are for example purposes only and do not display upgrade phase values unless a specific request to verify the phase is given, i.e., Procedure 6, step 15. The goal in doing this is to make this document describe the generic upgrade procedure.
The following table lists the phase flags displayed during the upgrade process. These flags are used to indicate the progress made by the upgrade function. The internal upgrade processing, which is initiated by the activate-upgrade command, controls these flags.
Table 2-2 Phases of Upgrade Execution
| Release Displayed | Phase Indicator[1] | Conversion | Software Running | Database Configuration |
| Source | Source | Source | ||
| Source | Phase 0 | Database | Target | Source |
| Target | Phase 2 | Database | Target | Target |
| Target | Phase 3 | Network | Target | Target |
| Target | Target | Target |
