4.433 rept-stat-sip
Use this command to display the overall status of the SIP service on the EAGLE.
Parameters
- loc (optional)
- The SIP card location for which SIP TPS usage data is to be reported.
- Range:
1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 – 6118
Example
rept-stat-sip
rept-stat-sip:peakreset=yes:loc=1101
rept-stat-sip:loc=1101
rept-stat-sip:mode=perf
rept-stat-sip:mode=perf:loc=1101
Dependencies
The location specified with this command should be of a SIP card.
A SIP card running the SIPHC application must be configured before this command can be entered.
Parameter peakreset should be specified with loc parameter.
Notes
If optional parameters are specified, only the entries that match the entered parameters are displayed.
Output
This example displays output when no parameter is specified:
rept-stat-sip
tekelecstp 02-03-20 05:58:25 EST EAGLE 46.0.0
rept-stat-sip
SIP ALARM STATUS = No Alarms
SIP cards Configured= 2 Cards IS-NR= 2
CARD VERSION PST SST AST TPS
1107 045-003-053 IS-ANR Standby 100%+ 0
TOTAL SERVICE STATISTICS:
SERVICE SUCCESS ERROR WARNINGS BYPASS TOTAL
SIPNP: 5 2 1 2 10
Command Completed.
This example displays output when the LOC parameter is specified:
rept-stat-sip:loc=1107
Command Accepted - Processing
tekelecstp 02-03-20 06:00:17 EST EAGLE 46.0.0
CARD VERSION TYPE PST SST AST
1101 045-003-053 DSM IS-NR Active -----
CARD ALARM STATUS = No Alarms
TPS STATISTICS
TPS PEAK TPS. PEAKTIMESTAMP
2503 2508 02-03-20 06:02:04
PER CONNECTION STATISTICS
CNAME STATUS TPS INVITE 3XX ERROR
C1 DOWN 0 0 0 0
C2 DOWN 0 0 0 0
C3 UP 2503 75113 75113 0
UdpC4 UP 0 0 0 0
Command Completed.
This example displays output when the MODE parameter is specified:
tekelecstp 02-03-20 06:05:55 EST EAGLE 46.0.0
SIP Cards Configured= 2 Cards IS-NR= 2
TPS STATISTICS:
CARD TPS PTPS PTIMESTAMP
1101 P 2507 2511 02-03-20 06:05:52
1107 0 0 00-00-00 00:00:00
Command Completed.
This example displays output when both MODE and LOC parameters are specified:
tekelecstp 02-03-20 06:08:24 EST EAGLE 46.0.0
TPS STATISTICS:
2501 2517 02-03-20 06:06:21
PER CONNECTION STATISTICS:
CNAME TPS PTPS PTIMESTAMP
C1 0 0 00-00-00 00:00:00
C2 0 0 00-00-00 00:00:00
C3 2501 2517 02-03-20 06:06:21
udpC4 0 0 00-00-00 00:00:00
Command Completed.
