act-gpl
Use this command to change the status of the trial GPL from “trial” to “approved.” The status of the previously approved GPL is changed to “trial.”
Parameters
gpl (mandatory)
Generic program load. The name of the GPL identifier to be moved from "trial" to "approved" status on the disk.
Range:
xyyyyyyy
1 alphabetic character followed by up to 7 alphanumeric characters. Valid GPLs are:
atmhc/atmhc69—Used by E5-ATM-B cards to allow the card to support up to 3 signaling links.
bldc32—Flash GPL containing a tar image with all code required on E5-MCAP cards to support VxWorks6.9 32-bit application, as in OAMHC69.
bldc64—Flash GPL containing a tar image with all code required on E5-SM8G-B cards for SCCP64, ENUM64, SIP64 and DEIR64 applications.
blmcap—Flash GPL containing a tar image with all code required on E5-MCAP, E5-E1T1-B, E5-MCPM-B, E5-ATM-B, E5-ENET-B, and E5-SM8G-B cards
blslc32—Flash GPL containing a tar image with all code required on SLIC cards for 32-bit application i.e. MCPHC, IPSHC etc.
blslc64—Flash GPL containing a tar image with all code required on SLIC cards for 64-bit application i.e. SCCP64, ENUM64, SIP64 and DEIR64.
blsl932—Flash GPL containing a tar image with all code required on SLIC cards for 32-bit application on VxWorks6.9, as in IPSHC69 and MCPHC69.
blbw32—Flash GPL containing a tar image with all code required on SLICV3 cards for 32-bit application i.e. MCPHC69, SS7HC69, ERTHC69, IPSG69, IPSG932.
blbw64—Flash GPL containing a tar image with all code required on SLICV3 cards for 64-bit application i.e. SCCP64, ENUM64, SIP64 and DEIR64. —Flash GPL containing a tar image with all code required on SLICV3 cards for 32-bit application i.e. MCPHC69, SS7HC69, ERTHC69, IPSG69, IPSG932.
deir64— Used by E5-SM8G-B and SLIC cards to support the S13/S13' EIR feature.
enum64—Used by E5-SM8G-B and SLIC cards to support the ENUM Mobile Number Portability and Tier One Address Resolution application.
erthc/erthc69—Used by E5-ENET-B and SLIC cards for EAGLE 5 Integrated Monitoring Support functions
hipr2—Communication software used on the High Speed IMT Packet Router (HIPR2) card
ipsg/ipsg69—Used by E5-ENET-B and SLIC cards to support the combined functionality of IPSG M2PA and IPSG M3UA
ipsg32/ipsg932—Used by SLIC cards to support IPSG application with 32-bit addressing either with GTT functionality or without it.
ipshc—Used by E5-ENET-B cards to support the IPS application.
ipshc69—Used by E5-ENET-B and SLIC cards to support the IPS application when running on VxWorks69.
mcphc— Used by E5-MCPM-B cards for the Measurements Platform feature.
mcphc69—Used by E5-MCPM-B and SLIC cards for the Measurements Platform feature when running on VxWorks69.
oamhc—Used by E5-MCAP cards for enhanced OAM functions.
oamhc69—Used by E5-MCAP cards for enhanced OAM functions, when running on VxWorks 69.
sccp64—Used by E5-SM8G-B and SLIC cards to support EPAP-based features and the LNP ELAP Configuration feature. If no EPAP-based or LNP ELAP Configuration feature is turned on, and an E5-SM8G-B or SLIC card is present, then the GPL processes normal GTT traffic.
sip64— Used by E5-SM8G-B and SLIC Cards to support the SIP application.
ss7hc/ss7hc69—Application GPL used by E5-E1T1-B and SLIC cards to support E1 and T1 signaling links.
ver (mandatory)
Version. The version number of the GPL to be activated, with subfields the format of major-minor-fix separated by dashes.
Range:
major-minor-fix
Specify a value in the range 0–255 for each subfield of the GPL version number (major-minor-fix).
Example
act-gpl:gpl=ss7hc:ver=125-1-0
act-gpl:gpl=deirhc:ver=134-60-0
act-gpl:gpl=enumhc:ver=135-20-0
act-gpl:gpl=ipsg32:ver=140-12-0
Dependencies
No other activate, change, copy, or retrieve GPL commands, nor a GPL audit, can be in progress when this command is entered.
The value specified for the gpl parameter must be supported. See the gpl definition for a list of supported GPLs.
Notes
Test the trial GPL by loading to a card before activating the GPL. Activating the GPL changes it from trial to approved.
The generic program load is committed on the active system and on the standby system.
Trial GPLs are downloaded to cards manually. Only approved GPLs can be downloaded to cards by the system.
Use the rtrv-gpl command to determine the version of the GPL.
Output
The output indicates that the specified GPL is activated on each TDM card.
    tekelecstp 05-01-03 16:53:23 EST  EAGLE5 33.0.0
    SS7HC activate to 1114 completed
    SS7HC activate to 1116 completed
act-gpl:gpl=deirhc:ver=134-60-01
    tekelecstp 13-03-15 19:08:39 EST EAGLE 45.1.0
    DEIRHC activate to 1114 completed
    DEIRHC activate to 1116 completed
    tekelecstp 14-05-20 14:18:32 EST EAGLE 46.1.0
    ENUMHC activate to 1114 completed
    ENUMHC activate to 1116 completed
tekelecstp 12-08-16 09:35:00 EST EAGLE 46.5.0
    IPSG32 activate to 1114 completed
    IPSG32 activate to 1116 completed
The number of "cards of x complete" represents the total number of cards that can communicate on the IMT at the instant that this information is displayed.
act-gpl:gpl=hipr2:ver=135-041-000
    tekelecstp 15-04-16 11:12:45 EST  EAGLE5 46.2.0-65.42.0
    5575.1104    CARD 1107,A   INFO    IP Connection Failed
    tekelecstp 15-04-16 11:12:49 EST  EAGLE5 46.2.0-65.42.0
    Command entered at terminal #20.
Command Accepted - Processing
    tekelecstp 15-04-16 11:12:50 EST  EAGLE5 46.2.0-65.42.0
    HIPR2 activate on 1116 completed
    HIPR2 activate on 1114 completed
