act-lg-card
Use this command to activate LG event generation/reception on a given LG card
The command class is TKLC_INTERNAL inheriting properties of DEBUG class. The Load Generator is supported on IPSG, IPLHC, IPGHC and SS7HC GPLs.Parameters
- loc (mandatory)
- The card location as stenciled on the shelf of the system.
- Range:
- 1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118
Example
act-lg-card:loc=1302
act-lg-card:loc=1302:dir=tx
act-lg-card:loc=1302:dir=rx
Dependencies
The card location must not be 1113-1118, xy09, or xy10 where x is the frame and y is the shelf.
The LG Card table is corrupt or cannot be found.
The card location specified in the loc parameter must be of a provisioned LG card.
Loc is mandatory
Activating the state of an LG object that is already activated or deactivating the state of an LG object that is already deactivated has no effect.
Output
None.
