canc-echo
Use this command to halt the echoing of command responses from the user’s terminal to other terminals or printers.
Parameters
Example
canc-echo
canc-echo:trm=7
Dependencies
The echo cannot be cancelled to the same terminal from which the canc-echo command is entered.
An act-echo command must be active at the specified terminal before this command can be entered to cancel the echo.
Notes
Only the echoing of command output responses can be halted by this command. To halt the printing of alarm and network messages, the chg-trm command must be used.
Output
canc-echo
rlghncxa03w 04-01-07 11:11:28 EST EAGLE 31.3.0
canc-echo
Command entered at terminal #6.
Scroll Area Output echo disabled to all terminals.
canc-echo:trm=7
canc-echo:trm=7
Scroll Area Output echo disabled for terminal 7.
