Converting Multiple-Part ITU National Point Codes
To make this conversion, you will need to know the format of the ITU national point code. This can be verified in the npcfmti field of the rtrv-stpopts command output. For this example, the ITU national point codes 7-55-5 and 0-86-7, using the 3-8-3-0 point code format, are converted into a single number.
Convert multiple-part ITU national point codes to a single number as follows.
Converting Multiple-Part ITU National Point Codes to a Single Number
