Converting Single Number ITU National Point Codes
To make this conversion, you will need to know the format of the ITU national point code. This can be verified in the NPCFMTI field of the rtrv-stpopts command output. For this example, the ITU national point codes 14781 and 695 are converted to point codes using the 3-8-3-0 format.
Convert a single number ITU national point code to a multiple-part ITU national point code as follows.
