Point Code Formats and Conversion
Many of the commands used for database configuration use point codes. This section describes the point code formats that the system supports. If you need additional information or procedural information, refer to the Database Administration Manual - SS7.
The system supports four different point code formats:
  • ANSI point codes
  • ITU International point codes
  • ITU National point codes
  • ITU National 24-bit point codes
Each format is described in further detail in the following sections.
