rept-imt-info
Use this command to display the following statistics:
- IMT bus error statistics currently stored in the IMT fault isolation hourly statistics
- Current IMT bus use statistics. Bus use is the percentage of the capacity of the IMT bus that is used for data during a particular time.
- MUX card error statistics
Parameters
- ebucket (optional)
- End bucket. The last one-hour time period (bucket) for which error statistics are reported.
- eloc (optional)
- End location. Specifies the card location of the
last card in the range for the report.
- Range:
- 1101 - 1113, 1115, 1201 - 1218, 1301 - 1318, 2101 - 2118, 2201 - 2218, 2301 - 2318, 3101 - 3118, 3201 - 3218, 3301 - 3318, 4101 - 4118, 4201 - 4218, 4301 - 4318, 5101 - 5118, 5201 - 5218, 5301 - 5318, 6101 - 6118
- Default:
- If
sloc is specified—current
sloc value; displays
information for one card
If sloc is not specified—1115, which corresponds to IMT address 251 (e=251); displays information for entire range of locations.
- erronly (optional)
- This parameter filters the output to display only non-zero counts in the error report.
- eshelf (optional)
- The end shelf location for MUX statistics. This shelf location is the last shelf in the range.
- sbucket (optional)
- Start bucket. The first one-hour time period (bucket) for which error statistics are reported.
- sloc (optional)
- Start location. The card location of the first
- Range:
- Default:
eloc is specified—current
eloc value
eloc and sloc are not specified—displays information for entire range of card locations
- sshelf (optional)
- The starting shelf location for MUX statistics. This location is the first shelf in the range.
Example
rept-imt-info:report=err
rept-imt-info:report=err:sloc=1101:eloc=1102:mode=stats
rept-imt-info:report=err:sloc=1101:eloc=1102:mode=full:erronly=no
rept-imt-info:report=hiprerr:sbucket=0
rept-imt-info:report=hiprerr:sshelf=1100:sslot=1:eslot=2:sbucket=0
Dependencies
No related IMT command can be in progress when this command is entered. Only one report can be active at a time.
This command cannot be entered at a telnet terminal (terminal ID 17-40).
This command cannot be entered during an IMT statistics collection period following an hourly boundary (IMT performance monitoring).
The ending hourly time period cannot be less than the starting hourly time period.
If the sslot and eslot parameters are specified, then the sshelf parameter must be specified and the eshelf parameter cannot be specified (slot information is reported for a single shelf).
A value of hmuxerr, hiprerr, or hipr2err must be specified for the report parameter before the sshelf and eshelf parameters can be specified.
The MUX card slots (09 and 10) cannot be specified for the sslot and eslot parameter values.
A card location that is valid and defined in the database must be specified.
This command cannot be entered during an Extended Bit Error Rate Test (BERT).
The shelf locations specified by the sshelf and eshelf parameters must be provisioned in the frame.
The report=err parameter must be specified before the erronly and mode parameters can be specified.
The sshelf parameter must be specified, and a value of hiprerr or hipr2err must be specified for the report parameter before the sslot and eslot parameters can be specified.
A value of hiprerr, hipr2err, or hmuxerr must be specified for the report parameter before the sshelf or eshelf parameter can be specified.
Notes
This command can be canceled using the
F9 function key
or the
canc-cmd command. See
canc-cmd
for more information.
Hourly Bucket Statistics
Hourly Bucket Statistics apply to cards on the IMT bus and to MUX cards. Each hourly time period (bucket) contains the statistics for a single hour. A total of 16 hourly time periods, numbered 0 - 15, exist. Hourly time period 0 is the most-recent (current), and hourly time period 15 is the least-recent (oldest).
Each hour the statistics for the current hourly time period expire, and the hourly time periods advance. That is, after the advance, the statistics previously reported in hourly time period 0 are now reported in the hourly time period 1, and so on. The statistics reported in the hourly time period 15 are no longer available after the change.
When a card is reinitialized, it begins collecting statistics in hourly time period 0 and changes to hourly time period 1 at the start of the next hour. Thus, the first statistics that a card collects after being reinitialized may be for a partial hour.
MUX Statistics
A MUX card stores the statistics separately for each card on its shelf. If the sloc and eloc parameters are specified, then the card sends the statistics for each card to the OAM application for display. If the sloc and eloc parameters are not specified, then the card sends an aggregate number to the OAM application to represent statistics for all cards on its shelf.
Low Speed Summary
Table 4-43 rept-imt-info Statistics, Low Speed Summary (rept-imt-info:report=(hmuxerr, hiprerr, or hipr2err))
| Stat Label – Low Speed Error & Event Counts | Explanation of Stat | Probable Cause | Recommended Action |
| IMT Rx Packet CRC Error |
Receive CRC error: Bad Checksum in received IMT packet. Caused by corrupted data within the received packet. Detected by hardware. |
Maintenance activity: Card insertion, removal, or boot. Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue is present. Contact the Customer Care Center. |
| IMT Rx Packet Format Error |
Receive Format error: Occurs when the End of Message byte of an IMT packet is found missing. Detected by hardware/software. |
| IMT Rx Violation Error |
Violation Error: Received an illegal character from the physical IMT transport (TAXI Interface). Detected by hardware |
Card insertion, removal, or boot or defective hardware | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Rx Command Error | Reserved. | Reserved. | Reserved. |
| IMT Rx FIFO Full | Receive FIFO Full: Watermark indication that this interface receiving data off the TAXI line is receiving traffic in excess of what it can handle. Some traffic will have been discarded. May cause retransmissions, CRC errors and Format errors. | Relatively heavy traffic on this interface can cause these counts to increment. If these counts occur in the field, a software problem may exist. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Rx FIFO Half Full | Receive FIFO Half Full: Watermark indication that the interface receiving data off the TAXI line has received substantial traffic. | Relatively heavy traffic on this interface can cause these counts to increment. | None. FIFO Half Full is an indication; no action is required. |
| IMT Tx FIFO Full |
Transmit FIFO Full: The FIFO has overflowed and data has been lost. This stat is only meaningful for MUX card columns. |
Relatively heavy traffic on this interface can cause these counts to increment. This condition should never occur. These events may indicate a software problem | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Tx FIFO Half Full |
Transmit FIFO Half Full: Watermark indication that this interface is backed up through ½ of its available storage. This stat is only meaningful for MUX card columns. |
Indicates that data was transmitted at a relatively high rate for a short period. | None. FIFO Half Full is just an indication; no action is required. |
| CPU Rx FIFO Empty Before SOM | Occurs when valid packet data is read from the CPU Rx FIFO and the beginning (SOM) of the packet is found missing before all data was read. | The SOM was corrupted while being written into the CPU Rx FIFO from the low speed link. | None. This error will automatically empty the FIFO so it is ready to continue receiving data. If the error continues, contact the Customer Care Center. |
| CPU Rx FIFO Empty Before EOM | Occurs when valid packet data is read from the CPU Rx FIFO and the end (EOM) of the packet is found missing before all data was read. | The SOM was corrupted while being written into the CPU Rx FIFO or a partial packet was written into the FIFO from the low speed link. | None. This error will automatically empty the FIFO so that it is ready to continue receiving data. If the error continues, contact the Customer Care Center. |
| CPU Rx Packet SOM Before EOM | A Start of Message was received when an End of Message was expected from the IMT bus. | Packet was corrupted in the system (EOM lost) and has another packet appended to it. | None. If the problem persists, contact the Customer Care Center. |
| CPU Rx Packet CRC Error | Occurs when valid packet data is read from the CPU Rx FIFO and transferred to the processor memory and calculated CRC does NOT match the CRC word at the end of the packet. | The data was corrupted while being written into the CPU Rx FIFO or data coming from the low speed link is corrupted. | None. If the problem persists, contact the Customer Care Center. |
| DMA Terminal Count | Received IMT packet length is longer than the max allowed. Detected by hardware. | Card insertion/removal or boot. | None if card has booted or was just inserted. Clear the stats and if the problem persists, contact the Customer Care Center. |
| CPU Tx Buffer EOB | A packet that was being transmitted from the CPU Tx Buffer did not have an EOM. | The data was corrupted while being written into or being read from the FIFO. | None. If the problem persists, contact the Customer Care Center. |
| CPU Tx Buffer Full | Transmit Buffer Full: The Tx Buffer unexpectedly filled up. | Either the COM software attempted to transmit too much data at once or the Tx logic was unable to transmit the data. | None. If the problem persists, contact the Customer Care Center. |
| CPU Tx Buffer Half Full | Transmit Buffer Half Full: Watermark indication that this interface is backed up through ½ of its available storage. | Relatively heavy outbound traffic on this interface can cause these counts to increment. | None. Buffer Half Full is just an indication, no action is required. |
| CPU Rx FIFO Full | Receive FIFO Full: The Rx FIFO unexpectedly filled up. | Indicates that data was received at a higher rate than could be processed by the Communications processor. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center. |
| CPU Rx FIFO Half Full | Receive FIFO Half Full: Watermark indication that this interface is backed up through ½ of its available storage. | Relatively heavy inbound traffic on this interface can cause these counts to increment. | None. FIFO half full is just an indication, no action is required. |
| IMT Bypass FIFO Full | IMT Bypass FIFO Full: The bypass FIFO unexpectedly filled up. | Relatively heavy traffic on this interface can cause these counts to increment. If these counts occur in the field, a software problem may exist. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Bypass FIFO Half Full | IMT Bypass FIFO Half Full: Watermark indication that this interface is backed up through ½ of its available storage. | Relatively heavy inbound traffic on this interface can cause these counts to increment. | None. FIFO half full is just an indication, no action is required. |
High Speed Summary
Table 4-44 rept-imt-info Statistics, High Speed Summary
| Stat Label – High Speed Error & Event Counts | Explanation of Stat | Probable Cause | Recommended Action |
| IMT Rx Disparity Error | Fibre Channel Receive Packet with Disparity Errors: Parity error in received packet. Usually caused by corrupted data. | Should not occur in a properly functioning system and may indicate a hardware failure. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Rx Sync Lost Error (This error count is not used in MUX card.) |
Fibre Channel Receive Lost Synchronization Errors: The receiver on this interface lost synchronization. |
| IMT Rx Code Word Error | Fibre Channel Receive code Word Errors: Error in received packet. Caused by corrupted data. | Should not occur in a properly functioning system and may indicate a hardware failure. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Rx Packet SOM Before EOM | Fibre Channel Receive Packet with Start of Message without a previous End of Message Errors: The software detected the start of a new packet before the end of the previous packet was detected. | Should not occur in a properly functioning system and may indicate a hardware failure. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact Customer Care Center. |
| IMT Bypass FIFO Full | Fibre Channel Bypass FIFO Full: The FIFO has over run and data has been lost. May result in significant downstream errors. | Should not occur in a properly functioning system, and may indicate a software or hardware failure. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Bypass FIFO Half Full | Fibre Channel Bypass FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. | Relatively heavy traffic on this interface can cause these counts to increment. | None. FIFO Half Full is just an indication: no action is required. |
| IMT Rx FIFO Full | Fibre Channel Receive FIFO Full: The FIFO has over run and data has been lost. May result in significant downstream errors. | Should not occur in a properly functioning system. Indicates a software or hardware failure | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center. |
| IMT Rx FIFO Half Full | Fibre Channel Receive FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. | Relatively heavy traffic on this interface can cause these counts to increment. | None. FIFO Full in this case is just an indication; no action is required. |
| IMT Tx FIFO Full | Fibre Channel Transmit FIFO Full: Watermark indication that this interface has transmitted substantial traffic. | Relatively heavy traffic on this interface can cause these counts to increment. | None. FIFO Full in this case is just an indication; no action is required. |
| IMT Tx FIFO Half Full | Fibre Channel Transmit FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. | Relatively heavy traffic on this interface can cause these counts to increment. | None. FIFO Half Full is just an indication; no action is required. |
| CPU Rx Fifo Full | Receive FIFO Full: The Rx FIFO unexpectedly filled up. | Indicates that data was received at a higher rate than could be processed by the Communications processor. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center. |
| CPU Rx FIFO Empty Before SOM | Occurs when valid packet data is read from the CPU Rx FIFO and the beginning (SOM) of the packet is found missing before all data was read. | The SOM was corrupted while being written into the CPU Rx FIFO from the high speed link. | None. This error will automatically empty the FIFO so that it is ready to continue receiving data. If the problem persists, contact the Customer Care Center. |
| CPU Rx FIFO Empty Before EOM | Occurs when valid packet data is read from the CPU Rx FIFO and the beginning (SOM) of the packet is found missing before all data was read. | The SOM was corrupted while being written into the CPU Rx FIFO or a partial packet was written into the FIFO from the high speed link. | None. This error will automatically empty the FIFO so that it is ready to continue receiving data. If the problem persists, contact the Customer Care Center. |
| CPU Rx Packet SOM Before EOM | A Start of Message was received when an End of Message was expected from the Fibre Channel bus. | Packet was corrupted in the system (EOM lost) and has another packet appended to it. | None. If the problem persists, contact the Customer Care Center. |
| CPU Rx Packet CRC Error | Occurs when valid packet data is read from the CPU Rx FIFO and transferred to the processor memory and calculated CRC does NOT match the CRC word at the end of the packet. | The data was corrupted while being written into the CPU Rx FIFO or data coming from the high speed link is corrupted. | None. If the problem persists, contact the Customer Care Center. |
| DMA Terminal Count | Received IMT packet length (on Fibre Channel) is longer than the max allowed. Detected by hardware. | Card insertion/removal or boot. | None if card has booted or was just inserted. Clear the stats and if the problem persists, contact the Customer Care Center. |
| CPU Tx Buffer EOB | A packet that was being transmitted from the CPU Tx Buffer did not have an EOM. | The data was corrupted while being written into or being read from the FIFO. | None. If the problem persists, contact Customer Care Center. |
| CPU Tx Buffer Half Full | Transmit Buffer Half Full: Watermark indication that this interface is backed up through ½ of its available storage. | Relatively heavy outbound traffic on this interface can cause these counts to increment. | None. Buffer Half Full is an indication, no action is required. |
| IXP Rx FIFO Full | Fibre Channel IXP Receive FIFO Full: The IXP Rx FIFO momentarily became full. This event can occur under normal conditions and it does not indicate an issue. | Relatively heavy traffic on this interface can cause these counts to increase. | None. FIFO Full in this case is just an indication; no action is required. |
| IXP Rx FIFO Half Full | Fibre Channel IXP Receive FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. | Relatively heavy traffic on this interface can cause these counts to increment. | None. FIFO Full in this case is just an indication; no action is required. |
| IMT Rx Byte Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Rx Byte Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Tx Byte Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Tx Byte Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Rx Packet Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Rx Packet Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Tx Packet Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Tx Packet Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Rx Errors Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Rx Errors Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Tx Errors Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Tx Errors Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Rx Safety Per Minute AVG | Average per minute | Normal behavior | None. Information only. |
| IMT Rx Safety Per Second AVG | Average per second | Normal behavior | None. Information only. |
| IMT Rx MSU Byte Per Minute AVG | Average bytes per minute received on the line card interface within reliable delivery packets. | Normal behavior | None. Information only. |
| IMT Rx MSU Byte Per Second AVG | Average bytes per second received on the line card interface within reliable delivery packets. | Normal behavior | None. Information only |
| IMT Rx ASU Byte Per Minute AVG | Average bytes per minute received on the line card interface within acknowledgment packets. | Normal behavior | None. Information only. |
| IMT Rx ASU Byte Per Second AVG | Average bytes per second received on the line card interface within acknowledgment packets. | Normal behavior | None. Information only |
| IMT Rx DSU Byte Per Minute AVG | Average bytes per minute received on the line card interface within best effort delivery packets. | Normal behavior | None. Information only. |
| IMT Rx DSU Byte Per Second AVG | Average bytes per second received on the line card interface within best effort delivery packets. | Normal behavior | None. Information only. |
| IMT Rx MSU Byte Count | Number of bytes received on the line card interface within reliable delivery packets. | Normal behavior | None. Information Only |
| IMT Rx ASU Byte Count | Number of bytes received on the line card interface within acknowledgment packets. | Normal behavior | None. Information only. |
| IMT Rx DSU Byte Count | Number of bytes received on the line card interface within best effort delivery packets. | Normal behavior | None. Information only. |
| IMT RX HSU Byte Count | Number of bytes received on the line card interface within mux specific packets. | Normal behavior | None. Information only. |
| IMT Rx LSSU Byte Count | Number of bytes received on the line card interface within virtual circuit alignment packets. | Normal behavior | None. Information only. |
| IMT Rx TSU Byte Count | Number of bytes received on the line card interface within test data packets. | Normal behavior | None. Information only |
| IMT Rx SSU Byte Count | Number of bytes received on the line card interface within safety packets. | Normal behavior. | None. Information only. |
| IMT Rx BSU Byte Count | Number of bytes received on the line card interface within broadcast packets. | Normal behavior | None. Information only. |
| IMT Rx Byte Other | Number of bytes received on the line card interface within data packets other than the above. | Normal behavior | None. Information only. |
| IMT Rx Total Byte Count | Number of bytes received on the line card interface within all types of packets. | Normal behavior | None. Information only. |
| IMT Rx MSU Packet Count | Number of reliable delivery packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx ASU Packet Count | Number of acknowledgment packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx DSU Packet Count | Number of best effort delivery message data packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx HSU Packet Count | Number of mux card data packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx LSSU Packet Count | Number of virtual circuit alignment packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx TSU Packet Count | Number of test data packets received on the IMT. | Normal behavior. | None. Information only. |
| IMT Rx SSU Packet Count | Number of safety packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx BSU Packet Count | Number of broadcast data packets received on the IMT. | Normal behavior | None. Information only. |
| IMT Rx Packet Other | Number of all packets types not counted by one of the above. | Normal behavior | None. Information only. |
| IMT Rx Total Packet Count | Number of packets received on the IMT, all types. | Normal behavior | None. Information only. |
| IMT Rx MSU Packet Safety Count | Number of reliable delivery message data packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx ASU Packet Safety Count | Number of acknowledgment packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx DSU Packet Safety Count | Number of best effort delivery packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx HSU Packet Safety Count | Number of mux card packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx LSSU Packet Safety Count | Number of virtual circuit alignment packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx TSU Packet Safety Count | Number of test data packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx SSU Packet Safety Count | Number of safety packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx BSU Packet Safety Count | Number of broadcast data packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx Other Packet Safety Count | Number of other packets types not included above that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx Total Packet Safety Count | Number of all packets that did not arrive to the intended recipient on the IMT. | Normal behavior | None. Information only. |
| IMT Rx Packet Violation Error | Number of packets received that contained an illegal character. | Card insertion, removal, boot or defective hardware | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue exists. Contact Customer Care Center. |
| IMT Rx Packet CRC Error | Receive CRC error: Bad Checksum in received IMT packet. Caused by corrupted data within the received packet. Detected by hardware. | Card insertion, removal, or boot. Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue exists. Contact Customer Care Center. |
| IMT Rx Packet Format Error | Receive Format error: Occurs when the End of Message byte of an IMT packet is found missing. Detected by hardware/software. | Card insertion, removal, or boot. Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue exists. Contact Customer Care Center. |
| IMT Rx Packet Discard Error | Number of packets received that were discarded by this interface. | Relatively heavy traffic on this interface can cause these counts to increment. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear then there is no action to perform. If errors continue, a problem may exist. Contact Customer Care Center. |
| IMT Tx Packet Format Error | Number of packets transmitted that were detected to contain a data format error. | Maintenance activity: Card insertion, removal, or boot. Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear then there is no action to perform. If errors continue, a problem may exist. Contact Customer Care Center. |
| IMT Tx Packet Discard Error | Number of packets that were discarded by the transmit interface. | Relatively heavy traffic on this interface can cause these counts to increment. | Clear IMT stats, wait 1 hour and retrieve stats again. if stats are clear then there is no action to perform. If errors continue a problem may exist. Contact Customer Care Center. |
Miscellaneous Summary
Table 4-45 rept-imt-info Statistics, Miscellaneous Summary
| Shelf ID UART Framing Error | The Mux card at this location detected a framing error within the data stream containing its shelf address, transmitted by the MASP through the clock cable. | These errors can occur when a Mux card or a MASP has booted or been inserted/ removed from the slot. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center. |
| Shelf ID UART Overrun Error | The Mux card at this location detected a overrun error in the data stream containing its shelf address, transmitted by the MASP through the clock cable. | These errors can occur when a Mux card or a MASP has booted or been inserted/ removed from the slot. | Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center. |
Output
An asterisk (*) is appended to each statistic in the output when one or more MUX cards are unable to report statistics during the collection of IMT statistics.
IMT statistics are displayed as '-' instead of zero for
counts when the IMT bus is down or inhibited in the output for
rept-imt-info
reports for MUX cards.
rlghncxa03w 04-02-27 12:47:07 EST EAGLE 31.3.0
IMT Fault Isolation Error Statistics
SUMMARY REPORT: Totals accumulated from all requested cards for all buckets
Statistic Bus A Value Bus B Value
Rcv CRC Err 12 1
Primary Ctl Rcv Err 23 3
Violation Err 34 5
CPU Rcv FIFO Full 45 12
Totals accumulated from all requested cards for each bucket
Bucket Statistic Bus A Value Bus B Value
00 Rcv CRC Err 1 2
Rcv Invalid Len 1012345678 0
CPU Rcv FIFO Full 23 123
01 No errors in this bucket.
. (data continues for each hourly time period)
00 Rcv CRC Err 0 0
Rcv Format Err 0 0
Rcv Invalid Len 1 0
Primary Ctl Rcv Err 0 0
Primary Ctl Tx Err 0 0
Primary Ctl Sanity Err 0 0
Violation Err 1 0
IMT Rcv FIFO Half Full 0 0
IMT Rcv FIFO Full 0 0
CPU Rcv FIFO Half Full 0 0
CPU Rcv FIFO Full 0 0
MSU Retransmitted 0 0
DMA Terminal Ct Intrpt 0 0
SSU Pkts Txd 0 0
SSU Pkts Rcvd 0 0
01 Rcv CRC Err 3 0
Rcv Format Err 0 0
Rcv Invalid Len 0 0
Violation Err 0 0
SSU Pkts Txd 0 0
SSU Pkts Rcvd 0 0
Rcv CRC Err 3 0
Rcv Format Err 0 0
Rcv Invalid Len 1 0
Primary Ctl Rcv Err 1012345678 0
Violation Err 1 0
CPU Rcv FIFO Half Full 23 0
SSU Pkts Txd 1 0
SSU Pkts Rcvd 0 0
This example output displays the output when IMT Bus A and Bus B are normal and all HMUX cards are reporting the statistics:
rept-imt-info:report=hmuxerr:sbucket=0
rlghncxa03w 10-01-17 00:10:20 PST EAGLE 42.0.0
HMUX Summary Report: Summed across all requested cards for each bucket
Collecting HMUX stats: Extended processing time required.
HMUX Hourly Bucket Statistics
Bucket Low Speed Statistic BUS A Value BUS B Value
00 IMT Rx Packet CRC Error 0123456789 0123456789
IMT Rx Packet Format Error 0123456789 0123456789
IMT Rx Violation Error 0123456789 0123456789
CPU Rx FIFO Full 0123456789 0123456789
CPU Rx FIFO Half Full 0123456789 0123456789
CPU Rx FIFO Empty Before SOM 0123456789 0123456789
CPU Rx FIFO Empty Before EOM 0123456789 0123456789
CPU Rx Packet SOM Before EOM 0123456789 0123456789
CPU Rx Packet CRC Error 0123456789 0123456789
DMA terminal count 0123456789 0123456789
CPU Tx Buffer EOB 0123456789 0123456789
CPU Tx Buffer Full 0123456789 0123456789
CPU Tx Buffer Half Full 0123456789 0123456789
IMT Bypass FIFO Full 0123456789 0123456789
IMT Bypass FIFO Half Full 0123456789 0123456789
IMT Rx FIFO Full 0123456789 0123456789
IMT Rx FIFO Half Full 0123456789 0123456789
High Speed Statistic BUS A Value BUS B Value
IMT Rx Disparity Error 0123456789 0123456789
IMT Rx Sync Lost Error 0123456789 0123456789
IMT Rx Code Word Error 0123456789 0123456789
Misc Speed Statistic BUS A Value BUS B Value
Shelf ID UART Framing Error 0123456789 0123456789
Shelf ID UART Overrun Error 0123456789 0123456789
HMUX CUMULATIVE Statistics
This example shows the output when IMT Bus A and Bus B are normal and all MUX cards are reporting the statistics:
HIPR Summary Report: Summed across all requested cards for each bucket
HIPR Hourly Bucket Statistics
Bucket Loc Low Speed Statistic BUS A Value BUS B Value
00 ---- IMT Rx Packet CRC Error 0123456789 0123456789
IMT Rx Command Error 0123456789 0123456789
IMT Tx FIFO Full 0123456789 0123456789
IMT Tx FIFO Half Full 0123456789 0123456789
IMT Rx Packet SOM Before EOM 0123456789 0123456789
IXP Rx FIFO Full 0123456789 0123456789
IXP Rx FIFO Half Full 0123456789 0123456789
HIPR CUMULATIVE Statistics
This example shows the output when both IMT Bus A and Bus B are normal and all MUX cards are reporting the statistics:
00 1101 IMT Rx Packet CRC Error 0123456789 0123456789
00 1102 IMT Rx Packet CRC Error 0123456789 0123456789
; rept-imt-info:report=hipr2err:sbucket=0
tekelecstp 11-16-12 14:01:34 EST EAGLE 44.0.0
HIPR2 Summary Report: Summed across all requested cards for each bucket
HIPR2 Hourly Bucket Statistics
IMT Rx Byte Per Minute AVG 0123456789 0123456789
IMT Rx Byte Per Second AVG 0123456789 0123456789
IMT Tx Byte Per Minute AVG 0123456789 0123456789
IMT Tx Byte Per Second AVG 0123456789 0123456789
IMT Rx Packet Per Minute AVG 0123456789 0123456789
IMT Rx Packet Per Second AVG 0123456789 0123456789
IMT Tx Packet Per Minute AVG 0123456789 0123456789
IMT Tx Packet Per Second AVG 0123456789 0123456789
IMT Rx Errors Per Minute AVG 0123456789 0123456789
IMT Rx Errors Per Second AVG 0123456789 0123456789
IMT Tx Errors Per Minute AVG 0123456789 0123456789
IMT Tx Errors Per Second AVG 0123456789 0123456789
IMT Rx Safety Per Minute AVG 0123456789 0123456789
IMT Rx Safety Per Second AVG 0123456789 0123456789
IMT Rx MSU Byte Per Minute AVG 0123456789 0123456789
IMT Rx MSU Byte Per Second AVG 0123456789 0123456789
IMT Rx ASU Byte Per Minute AVG 0123456789 0123456789
IMT Rx ASU Byte Per Second AVG 0123456789 0123456789
IMT Rx DSU Byte Per Minute AVG 0123456789 0123456789
IMT Rx DSU Byte Per Second AVG 0123456789 0123456789
IMT Rx MSU Byte Count 0123456789 0123456789
IMT Rx ASU Byte Count 0123456789 0123456789
IMT Rx DSU Byte Count 0123456789 0123456789
IMT Rx HSU Byte Count 0123456789 0123456789
IMT Rx LSSU Byte Count 0123456789 0123456789
IMT Rx TSU Byte Count 0123456789 0123456789
IMT Rx SSU Byte Count 0123456789 0123456789
IMT Rx BSU Byte Count 0123456789 0123456789
IMT Rx Byte Other 0123456789 0123456789
IMT Rx Total Byte Count 0123456789 0123456789
IMT Rx MSU Packet Count 0123456789 0123456789
IMT Rx ASU Packet Count 0123456789 0123456789
IMT Rx DSU Packet Count 0123456789 0123456789
IMT Rx HSU Packet Count 0123456789 0123456789
IMT Rx LSSU Packet Count 0123456789 0123456789
IMT Rx TSU Packet Count 0123456789 0123456789
IMT Rx SSU Packet Count 0123456789 0123456789
IMT Rx BSU Packet Count 0123456789 0123456789
IMT Rx Packet Other 0123456789 0123456789
IMT Rx Total Packet Count 0123456789 0123456789
IMT Rx MSU Packet Safety Count 0123456789 0123456789
IMT Rx ASU Packet Safety Count 0123456789 0123456789
IMT Rx DSU Packet Safety Count 0123456789 0123456789
IMT Rx HSU Packet Safety Count 0123456789 0123456789
IMT Rx LSSU Packet Safety Count 0123456789 0123456789
IMT Rx TSU Packet Safety Count 0123456789 0123456789
IMT Rx SSU Packet Safety Count 0123456789 0123456789
IMT Rx BSU Packet Safety Count 0123456789 0123456789
IMT Rx Other Packet Safety Count 0123456789 0123456789
IMT Rx Total Packet Safety Count 0123456789 0123456789
IMT Rx Packet Violation Error 0123456789 0123456789
IMT Rx Packet Discard Error 0123456789 0123456789
IMT Tx Packet Format Error 0123456789 0123456789
IMT Tx Packet Discard Error 0123456789 0123456789
HIPR2 CUMULATIVE Statistics
This example shows the output when IMT Bus A is inhibited:
rlghncxa03w 10-01-27 00:10:20 PST EAGLE 42.0.0
00 ---- IMT Rx Packet CRC Error - 0
IMT Rx Packet Format Error - 0
IMT Rx Violation Error - 101
IMT Rx Command Error - 0
IMT Rx FIFO Full - 0
IMT Rx FIFO Half Full - 0
IMT Tx FIFO Full - 0
IMT Tx FIFO Half Full - 0
IMT Rx Disparity Error - 0
IMT Rx Sync Lost Error - 0
IMT Rx Code Word Error - 0
IMT Rx Packet SOM Before EOM - 0
IMT Bypass FIFO Full - 0
IMT Bypass FIFO Half Full - 0
IXP Rx FIFO Full - 0
IXP Rx FIFO Half Full - 0
Shelf ID UART Framing Error - 0
Shelf ID UART Overrun Error - 0
IMT Rx Violation Error - 1165
IMT Tx FIFO Half Full - 1
IMT Bypass FIFO Full - 1
IMT Bypass FIFO Half Full - 1
Shelf ID UART Framing Error - 35
This example shows the output when at least one card on the IMT Bus does not respond when statistics are collected:
00 ---- IMT Rx Packet CRC Error 0 0
IMT Rx Packet Format Error 0 0
IMT Rx Violation Error 128 0
IMT Rx Command Error 0 0
IMT Rx FIFO Full 0 0
IMT Rx FIFO Half Full 0 0
IMT Tx FIFO Full 36 0
IMT Tx FIFO Half Full 182 0
IMT Rx Disparity Error 0 0
IMT Rx Sync Lost Error 0 0
IMT Rx Code Word Error 0 0
IMT Rx Packet SOM Before EOM 0 0
IMT Bypass FIFO Full 0 0
IMT Bypass FIFO Half Full 0 0
IMT Tx FIFO Full 0 0
IMT Tx FIFO Half Full 0 0
IXP Rx FIFO Full 0 0
IXP Rx FIFO Half Full 0 0
Shelf ID UART Framing Error 2 0
Shelf ID UART Overrun Error 0 0
IMT Rx Packet CRC Error 0 0*
IMT Rx Packet Format Error 0 0*
IMT Rx Violation Error 1415 0*
IMT Rx Command Error 0 0*
IMT Rx FIFO Full 0 0*
IMT Rx FIFO Half Full 0 0*
IMT Tx FIFO Full 120 0*
IMT Tx FIFO Half Full 1113 0*
IMT Rx Disparity Error 0 0*
IMT Rx Sync Lost Error 15 0*
IMT Rx Code Word Error 0 0*
IMT Rx Packet SOM Before EOM 0 0*
IMT Bypass FIFO Full 1 0*
IMT Bypass FIFO Half Full 1 0*
IMT Tx FIFO Full 0 0*
IMT Tx FIFO Half Full 0 0*
IXP Rx FIFO Full 0 0*
IXP Rx FIFO Half Full 0 0*
Shelf ID UART Framing Error 59 0*
Shelf ID UART Overrun Error 0 0*
Legend
IMT Statistics:
- Bucket—The hourly time periods (buckets) for which a report was requested.
- Statistic—The error statistic type for the IMT buses A and B.
- Bus A Value—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus A.
- Bus B Value—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus B.
- Low Speed Statistic—The error statistic type for the low speed 125 Mbps secondary rings with MUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
- High Speed Statistic—The error statistic type for the high-speed 1 Gbps primary ring with MUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
- Misc Speed Statistics—Shelf ID Universal Asynchronous Receiver Transmitter (UART) error counts on the MUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
- Bucket Summary—The error
count for each parameter for one hour for HMUX cards installed on buses A (xy09 card locations) and B
(The count is for the most recent part of an hour if the card was booted within
an hour of executing the
rept-imt-infocommand.) - Cumulative—The running total error count for each parameter since card initialization for HMUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
MUX Statistics:
- Loc—The card location (shelf and slot) for which information is displayed.
- Misc Speed Statistic—The miscellaneous error statistic type.
- Bus A—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus A.
- Bus B—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus B.
Related Topics
