rept-stat-sip
Use this command to display the overall status of the SIP service on the EAGLE.
Parameters
loc (optional)
The SIP card location for which SIP TPS usage data is to be reported.
Range:
1101 - 1108, 1111 - 1112, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 – 6118
peakreset (optional)
Reset peak values to the current TPS values.
Range:
yes
no
Default:
no
mode (optional)
Performance data of SIP cards and their connections.
Range:
perf
Default:
perf
Example
rept-stat-sip
rept-stat-sip:peakreset=yes:loc=1101
rept-stat-sip:loc=1101
rept-stat-sip:mode=perf
rept-stat-sip:mode=perf:loc=1101
Dependencies
The location specified with this command should be of a SIP card.
A SIP card running the SIPHC application must be configured before this command can be entered.
Parameter peakreset should be specified with loc parameter.
Notes
If optional parameters are specified, only the entries that match the entered parameters are displayed.
Output
This example displays output when no parameter is specified:
rept-stat-sip
tekelecstp 02-03-20 05:58:25 EST EAGLE 46.0.0
    rept-stat-sip
    SIP ALARM STATUS = No Alarms
    SIP cards Configured= 2 Cards IS-NR= 2
    CARD   VERSION     PST           SST       AST       TPS
    1107   045-003-053 IS-ANR        Standby   100%+     0
    TOTAL SERVICE STATISTICS:
    SERVICE    SUCCESS    ERROR      WARNINGS   BYPASS     TOTAL
    SIPNP:     5          2          1          2          10
    Command Completed.
This example displays output when the LOC parameter is specified:
rept-stat-sip:loc=1107
Command Accepted - Processing
  tekelecstp 02-03-20 06:00:17 EST EAGLE 46.0.0
    CARD   VERSION      TYPE    PST            SST          AST
    1101   045-003-053  DSM     IS-NR          Active       -----
    CARD ALARM STATUS = No Alarms
    TPS STATISTICS
                 TPS   PEAK TPS.   PEAKTIMESTAMP
                 2503  2508        02-03-20 06:02:04
    PER CONNECTION STATISTICS
    CNAME              STATUS TPS    INVITE  3XX     ERROR
    C1                 DOWN   0      0       0       0
    C2                 DOWN   0      0       0       0
    C3                 UP     2503   75113   75113   0
    UdpC4              UP     0      0       0       0
  Command Completed.
This example displays output when the MODE parameter is specified:
  tekelecstp 02-03-20 06:05:55 EST EAGLE 46.0.0
    SIP Cards Configured= 2      Cards IS-NR= 2
    TPS STATISTICS:
    CARD   TPS    PTPS    PTIMESTAMP
    1101 P 2507   2511    02-03-20 06:05:52
    1107   0      0       00-00-00 00:00:00
    Command Completed.
This example displays output when both MODE and LOC parameters are specified:
  tekelecstp 02-03-20 06:08:24 EST EAGLE 46.0.0
    TPS STATISTICS:
                 2501  2517        02-03-20 06:06:21
    PER CONNECTION STATISTICS:
    CNAME              TPS    PTPS    PTIMESTAMP
    C1                 0      0       00-00-00 00:00:00
    C2                 0      0       00-00-00 00:00:00
    C3                 2501   2517    02-03-20 06:06:21
    udpC4              0      0       00-00-00 00:00:00
    Command Completed.
