rtrv-vlr-roaming
Use this command to display entries from the Visitor Location Register (VLR) Profile table.
Parameters
- oldvlr (optional)
- VLR Number from which mobile subscriber has moved, hexadecimal digit GT number with variable length (1 to 16).
Example
rtrv-vlr-roaming
rtrv-vlr-roaming:num=2
rtrv-vlr-roaming: newvlr=12345:oldvlr=56780
rtrv-vlr-roaming:vlrtbl=static
Dependencies
VLR_ROAM table must be accessible.
Both OLDVLR and NEWVLR must be specified
OLDVLR or NEWVLR parameter must be existing in VLR-PROF table
The entry should be existing in VLR_ROAM table
OLDVLR and NEWVLR parameter length must be in the range 1 to 5 digits as per current restriction.
Output
rtrv-vlr-roaming
tekelecstp 17-11-23 17:37:44 MST EAGLE 46.5.1.5.0-73.2.0
rtrv-vlr-roaming
Command entered at terminal #17.
Command Accepted - Processing
OLD_VLR NEW_VLR TIME
1234 56545 20
VLR-ROAMING table is (1 of 1000) 1% full.
rtrv-vlr-roaming:num=1
1234 56545 20
rtrv-vlr-roaming:oldvlr=1234:newvlr=56545
tekelecstp 17-11-23 17:39:12 MST EAGLE 46.5.1.5.0-73.2.0
1234 56545 20
tklc1110801 18-09-25 16:23:19 EST EAGLE 46.7.0.0.0-75.14.0
Command entered at terminal #2.
ab123 35100 240
ab456 35100 240
bb123 35100 240
bb456 35100 240
cd123 35100 240
cd456 35100 240
cc123 35100 240
cc456 35100 240
12345 35100 500
67890 35100 500
54321 35100 500
22222 35100 500
33333 35100 500
44444 35100 500
7444444455 6444444455 1440
77bbf23636 99eea09439 150
77bbf22222 99eea09439 300
77bbf29393 99eea42222 16
77bbf28765 99eea09393 60
88776655 887766554433 120
VLR-ROAMING table is (26 of 1000000) 1% full.
Related Topics
