Setting Up System Basics
Before configuring and deploying your Oracle Enterprise Communications Broker, you must establish some basic attributes such as new User and Superuser passwords, system prompt and enabling the Web GUI.
New User and Superuser Passwords
Acme Command Line (ACLI) passwords provide access for SSH, SFTP, and GUI
sessions. Common security practices include changing these passwords from their
defaults, and at intervals defined by your organization. Refer to the ACLI
secret command, documented in the
Oracle Communications Session Border Controller ACLI Reference
Guide, for information about changing user and superuser passwords.
Refer to the "Password Policy" section in the
Administrative Security Essentials Guide for information
about password requirements and policy configuration.
New System Prompt
You can set the ACLI system prompt using Configure system or the Set boot parameters System Operation. Change the target name value to make it meaningful within your network. The target name may be up to 38 characters. A value that identifies the system in some way is often helpful.
