7 Edge Nodes Inventory
The Edge Nodes page on the Inventory page lists the Cloud Connectors you use to support Oracle Enterprise Communications Platform (Oracle ECP) operations. You can set the column headings, select the search filters, and reach other information and operations from the page.
