Configuring Transmission Rates for WAN Interfaces
You can configure the transmission rate limits for a WAN interface on the Cloud Connector. This configuration allows you to control bandwidth allocation and quality of service (QoS) for the selected WAN interface, as opposed to the bandwidth performance test, which measures the actual WAN capacity.
Transmission rate configuration is available only for WAN interfaces. These include Broadband, Cellular, and Satellite connections. This option is not available for LAN interfaces.
  1. From the Edge Node Details page, click the Network tab.
  2. On the Network tab, select a WAN interface from the interface chooser.
  3. Click Bandwidth Distribution.
    Oracle ECP opens the Bandwidth Distribution drawer for the selected interface.
  4. In the Transmission Rate section, specify the required values that are within the allowed range for the following fields:
    • Upload Rate
    • Download Rate
  5. Do one of the following:
    • Click Update to apply the changes.
    • Click Cancel to discard the changes and return to the Network tab.
