Check Cloud Connector Interface Proxy and No Proxy
The Cloud Connector has a provision to include and/or exclude traffic destined for certain hosts by using standard proxy/noproxy provisions.
If your local network requires a destination proxy as an intermediary between networks, you can specify the details in the Cloud Connector UI. Likewise, you can configure a noproxy address (or address pattern) to specify exceptions for proxy usage.
You cannot change Proxy settings on an onboarded Cloud Connector. You must deboard the Cloud Connector and edit the proxy values from the local UI.Check a Cloud Connector's proxy settings
Although a Cloud Connector's proxy settings must
be completed prior to activation, they can be reviewed from the
Network tab of a Cloud Connector's details page.
- From the Network tab, choose the interface whose proxy you want to check.
- From the More Actions drop-down, choose View Proxy.
- The Proxy Settings drawer expands revealing the proxy information.
