Edge Nodes Inventory Page Column Headers
You can customize the Oracle Enterprise Communications Platform (Oracle ECP) Edge Node Inventory page by choosing from the following list of column headers to display the information you want to see.
Key to the following table:
  • * — Default header
  • ** — Sort and filter functions unavailable
Column Header Name Description
Name* Displays the name you specified for the Cloud Connector.
Life Cycle State* Displays the state of the Cloud Connector in Cloud Connector relative to being in service: Active | Inactive | Onboarded | Shipped.
Connectivity State* Displays the ability of the device to communicate with Oracle ECP.
Connectivity Type* Displays the specified connection types: Ethernet | Cellular | Satellite.
Ethernet* Displays the connectivity status of the Ethernet connection. Connected-green check mark | Disconnected-orange check mark | Hardware Error-red cross | Disabled -two dashes.
Cellular* Displays the connectivity status of the Cellular connection. Connected-green check mark | Disconnected-orange check mark | Hardware Error-red cross | Disabled -two dashes.
Satellite* Displays the connectivity status of the Satellite connection. Connected-green check mark | Disconnected-orange check mark | Hardware Error-red cross | Disabled -two dashes.
Serial Number* Displays the serial number of the Cloud Connector.
Organization* Displays the name of the organization to which this Cloud Connector belongs. If no organization displays, the Cloud Connector is considered Unassigned and is not associated with any Organization.
Make Displays the name of the brand or manufacturer of the device.
Model Displays the model number of the device as specified by the manufacturer.
Deployment Address Displays the address where the Cloud Connector is installed. Registration address is not displayed in the inventory table.
ICCID (SIM1) Displays the Integrated Circuit Card Identification number for SIM card number 1.
ICCID (SIM2) Displays the Integrated Circuit Card Identification number for SIM card number 2.
IMEI (SIM1) Displays the International Mobile Equipment Identity unique number for the Cloud Connector using SIM card number 1.
IMEI (SIM2) Displays the International Mobile Equipment Identity unique number for the Cloud Connector using SIM card number 2.
MNO (SIM1) Displays the name of the Mobile Network Operator providing connectivity for a cellular Cloud Connector with SIM card 1.
MNO (SIM2) Displays the name of the Mobile Network Operator providing connectivity for a cellular Cloud Connector with SIM card 2.
MNO Account (SIM1) Displays the name of the Mobile Network Operator providing connectivity for a cellular Cloud Connector. Displays the name of the MNO Account associated with the rate plan that defines connectivity services use.
MNO Account (SIM 2) Displays the name of the MNO Account using SIM card number 2 that defines the connectivity that services use.
APN (SIM1) Displays the name of the gateway between the mobile network and another computer network using SIM card number 1.
APN (SIM2) Displays the name of the gateway between the mobile network and another computer network using SIM card number 2.
Usage Status** Displays whether or not the Cloud Connector is in use: In Use | Not In Use.
Network Priority (SIM1)** Indicates whether or not the data traffic on the Cloud Connector using SIM card number 1 gets preferential treatment (for example, in a high-demand scenario) over the data traffic of other equipment using the cellular network: Yes | No.
Network Priority (SIM2)** Indicates whether or not the data traffic on the Cloud Connector using SIM card number 2 gets preferential treatment (for example, in a high-demand scenario) over the data traffic of other equipment using the cellular network: Yes | No.
Data Plan (SIM 1) Displays the amount of data (monthly usage tier) set by the data plan in use for an Cloud Connector equipped with SIM card number 1 from an MNO that supports changes to data usage. Note: An Cloud Connector equipped with a SIM card from an MNO that does not support data plan changes displays "- -" to indicate that data plan changes do not apply.
Data Plan (SIM 2) Displays the amount of data (monthly usage tier) set by the data plan in use for an Cloud Connector equipped with SIM card number 2 from an MNO that supports changes to data usage. Note: An Cloud Connector equipped with a SIM card from an MNO that does not support data plan changes displays "- -" to indicate that data plan changes do not apply.
Last Seen Timestamp Displays the date and time Oracle ECP last detected the Cloud Connector.
Terminal Serial Number Displays the satellite terminal serial number when satellite is used for connectivity.
Kit Serial Number Displays the serial number of the kit when satellite is used for connectivity.
For a Cloud Connector in the Shipped lifecycle state, Oracle ECP displays the available shipping and assignment information. Values that depend on onboarding or communication with the Cloud Connector are empty. These values can include IMEI, APN, usage status, network priority, last-seen timestamp, data plan, and network-interface connectivity status.
