Edit LAN DHCP or Static IP Values
You can configure the Dynamic Host Control Protocol (DHCP) server settings on a Cloud Connector's LAN interfaces. These are generally the Wi-Fi interfaces and properly assigned Ethernet ports.
Before You Begin
- Determine the LAN interface you want to configure DHCP on. name of a Cloud Connector with a configured Wi-Fi interface so that you can access the Edge Node Details page to edit the DHCP server settings.
- All interfaces share the same DHCP server, so you only need to set it once per Cloud Connector.
