Signal Quality Scorecard
The Oracle Enterprise Communications Platform (Oracle ECP) Signal Quality Scorecard displays information about the signal quality as a percentage during the time period you select for this scorecard.
In satellite communications, signal quality is about the reliability and clarity of the signal from the satellite to the satellite terminal. Signal strength meters on the satellite terminal assess the signal level and aggregate the data as a percentage.
Oracle ECP displays the aggregated percentage on the Signal Quality tab at the time you clicked the tab or when you click Refresh. Below the tab, Oracle ECP displays a line graph showing the percentage of signal quality in increments according to the time period you select.
