- ACLI Configuration Guide
- Getting Started
- Installation Wizard
- Run Setup
- Enable Basic Mode and Advanced Mode
- Enter
1
to enable Basic Mode and Advanced Mode or
2
to enable Advanced Mode only, and Press Enter.
Enter choice [1 - basic] :1Note:
If you enable both Basic and Advanced Modes (selection 1), after logging into the Web GUI, the Basic Mode screen displays by default. You can switch to Advanced Mode, if you do not make any changes in Basic Mode, using the Switch to Advanced button. If you enable Advanced Mode only (selection 2), the GUI does not display the Switch to Basic button.The following displays.
========================================================= HIGH AVAILABILITY This SBC may be a standalone or part of a highly available redundant pair. SBC mode 1 - standalone 2 - high availability Enter choice [1 - standalone] : ========================================================= - Type
1 for a standalone
server or enter
2 to configure an
High Availability (HA) device. Press Enter and go to Step 4 in
Setting
Up High Availability (HA) Mode to complete the installation.
Oracle recommends that you configure HA using this Installation Wizard.Enter choice [1 - standalone] :1The following displays.
========================================================= SBC SETTINGS Unique target name of this SBC [<SBC name>] : ========================================================= - Type
a unique
target name for the NN-ESD (or keep the default in [ ]),
, and press Enter.
Unique target name of this SBC [<SBC name>] :The following displays.
========================================================= IP address on management interface [<SBC IP address>] : ========================================================= - Type
the IP
address to be used for accessing the Web GUI (or keep the default in [ ]),
, and press Enter.
IP address on management interface [<SBC IP Address>] : 164.30.85.51The following displays.
========================================================= Subnet mask [<subnet mask>] : ========================================================= - Type the subnet
mask of the
Oracle® Enterprise Session Border Controller (or keep the default in [ ]), and press Enter.
Subnet mask [<subnet mask>] : 255.255.0.0The following displays.
========================================================= Gateway IP address [<Gateway IP address>] : ========================================================= - Type the gateway IP
address
(or keep
, and press Enter.
Gateway IP address [<Gateway IP address>] :164.30.0.1The following displays.
========================================================= -- Summary view ------------------------------------- GUI ACCESS 1: Enable Web GUI (yes/no) : yes WEB GUI MODE 2 : Web GUI Mode : basic HIGH AVAILABILITY 3 : SBC mode : standalone 4 : SBC role : N/A SBC SETTINGS 7 : Unique target name of this SBC : lise_primary 8 : IP address on management interface : 164.30.85.51 9 : Subnet mask : 255.255.0.0 10: Gateway IP address : 164.30.0.1 AUTOMATIC CONFIGURATION 11: Acquire config from the Primary (yes/no) : N/A PEER CONFIGURATION 13: Peer target name : N/A Enter 1 - 16 to modify, 'd' to display summary, 's' to save, 'q' to exit. [s]: =========================================================Note:
Only the fields that were configured display in the summary view. - Type
s to save the
configuration. Or select an item number from the summary view to modify the
value for that item. Or enter
q to exit the
installation wizard without saving the setup.
Enter 1 - 16 to modify, 'd' to display summary, 's' to save, 'q' to exit. [s] :sThe following displays.
========================================================= Saving changes and quitting wizard. Are you sure? [y/n]? : ========================================================= - Type
y to verify you want
to save the configuration and press Enter.
Saving changes and quitting wizard. Are you sure? [y/n]? :yThe following displays.
========================================================= Running configuration is backed up as 'bkup_setup_wizard_Apr_18_13_04_57_970.gz' ****************************************************** Deleting configuration Erase-Cache received, processing. waiting 1200 for request to finish Request to 'ERASE-CACHE' has Finished, Erase-Cache: Completed Request to 'RESTORE-CONFIG' has Finished, Restore Backup Completed Successfully checking configuration Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. ------------------------------------------------------ Verification successful! No errors nor warnings in the configuration Activate-Config received, processing. waiting for request to finish Request to 'ACTIVATE-CONFIG' has Finished, Activate Complete -- Saved configuration. ---------------------------- GUI ACCESS 1: Enable Web GUI (yes/no) : yes WEB GUI MODE 2 : Web GUI Mode : basic HIGH AVAILABILITY 3 : SBC mode : standalone 4 : SBC role : N/A SBC SETTINGS 7 : Unique target name of this SBC : jane_primary 8 : IP address on management interface : 164.30.85.51 9 : Subnet mask : 255.255.0.0 10: Gateway IP address : 164.30.0.1 AUTOMATIC CONFIGURATION 11: Acquire config from the Primary (yes/no) : N/A PEER CONFIGURATION 13: Peer target name : N/A You may access the GUI via http://164.30.85.51:80/ after reboot. =========================================================You completed the Installation Wizard.
You can configure the Web Server for using Transport Layer Security (TLS). You can also manage the Web Server using specific commands. For more information about configuring TLS on the Web Server, and for information about Web Server management commands, see "Web Server TLS Configuration and Management Commands."
