TCP Connection Tools
Transmission Control Protocol (TCP) connection tools can assist you in gauging performance, identifying potential memory leaks, and debugging connections for performance tracking and improvement.
The show ip tcp command shows the following socket connections by state:
  • inbound
  • outbound
  • listen
  • IMS-AKA
The show sipd tcp and show sipd tcp connections commands display counters to track usage. Use the reset sipd command to reset the counters.
