ACLI Configuration
To enable simultaneous payload type mapping of audio and DTMF:
  1. Navigate to the media-manager-config element.
    ACMEPACKET# configure terminal
    ACMEPACKET(configure)# media-manager
    ACMEPACKET(media-manager)# media-manager-config
    ACMEPACKET(media-manager-config)#
  2. options—Set the options parameter by typing options, a Space, the option-name audio-payload-type-mapping=yes with a “plus” sign in front of it, and then press Enter.
    ACMEPACKET(media-manager-config)# options +audio-payload-type-mapping=yes
    If you type the option without the “plus” sign, you will overwrite any previously configured options. In order to append the new options to the SIP interface configuration’s options list, you must prepend the new option with a “plus” sign as shown in the previous example.
  3. Save and activate your configuration.
