Simultaneous TCP Connection and Registration Cache Deletion
You can configure the Oracle® Enterprise Session Border Controller to automatically start a timer when a user deregisters or changes location by registering with a new contact address.
Not all devices tear down TCP connections associated with these old addresses when a user registers with a new contact address.
Registration Cache Deletion Configuration
You can apply suppress-reinvite to the sip-interface facing the User Agents whose re-INVITEs are to be responded to locally.
To enable Registration Cache Deletion:
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
    ORACLE(configure)#
  2. Type session-router and press Enter.
    ORACLE(configure)# session-router
    ORACLE(session-router)#
  3. Type sip-interface and press Enter. If you are adding this feature to a pre-existing configuration, you will need to select and edit it.
    ORACLE(session-router)# sip-interface
    ORACLE(sip-interface)#
  4. tcp-conn-dereg—The delay (in seconds) that is used to determine when to terminate the TCP connection for a user that has been removed from the registration cache or changed location. This feature can be disable by setting the value to zero.
    ORACLE(session-agent)# tcp-conn-dereg 5300
  5. Save your work.
