AMR-NB and AMR-WB Specifications
The Oracle® Enterprise Session Border Controller supports Adaptive Multi-Rate Narrow Band & Wide Band codecs. All configurations of this codec, as indicated by SDP, are transcodable except when the following SDP parameters are enabled:
- robust-sorting
 - interleaving
 - CRC
When AMR is configured in a codec policy’s add-codecs-on-egress parameter, it is forwarded from the Oracle® Enterprise Session Border Controller with the following default settings:
- 12.2 kbps (AMR-NB)
 - 23.85 kbps (AMR-WB)
 - RTP/IF1 format
 - No redundant packets
 - bandwidth efficient default payload
 - No CRC frame
 - 20ms default ptime
