Configure the Acme Packet 1100 Management Interface for HA
To enable communications between a pair of Acme Packet 1100 Oracle® Enterprise Session Border Controllers, configure the communication port for the pair. Perform all of the configuration on the active (ESBC) and then perform a synchronization, so that the peer can acquire the configuration.
                  		Before You Begin
               - Confirm that the management switch supports Virtual Local Area Network (VLAN) operations.
Procedure
               The Acme Packet 1100 uses the wancom0 port for HA operations. Specify wancom0 for name on the phy-interface.
                  		Next Steps
            - Configure the media interface virtual MAC address. See "Virtual MAC Address Configuration."
