If you are adding support for this feature to a preexisting
configuration, you must select (using the ACLI select
command) the single instance system-config element.
httpclient-max-total-conn—Set this parameter to
specify the maximum number of TCP connections that the
http-client allows open simultaneously or disable the
function. You cannot configure httpclient-max-total-conn
in real time. You must reboot the system whenever you make a change.
httpclient-cache-size-multiplier—Specifies the
multiplier used to calculate the size of the HTTP client connection cache. The
system maintains an HTTP connection cache pool. The size of the HTTP connection
cache is the number of pending transactions, multiplied by this
httpclient-cache-size-multiplier.
