5 About Persistent Protocol Tracing
You can configure sending protocol message logs off of the Oracle® Enterprise Session Border Controller, and have that persist after a reboot. You no longer have to manually issue the notify command each time you reboot.
To support persistent protocol tracing, you configure the following system-config parameters:
- call-trace—Enable/disable protocol message tracing (currently only sipmsg.log and alg.log) regardless of the process-log-level setting. If the process-log-level is set to trace or debug, call-trace will not disable.
- internal-trace—Enable/disable internal ACP message tracing for all processes, regardless of process-log-level setting. This applies to all *.log (internal ACP message exchange) files other than sipmsg.log and alg.log. If the process-log-level is set to trace or debug, call-trace will not disable.
- log-filter—Determine
what combination of protocol traces and logs are sent to the log server defined by
the process-log-ip parameter value. You can also fork the traces and logs, meaning
that you keep trace and log information in local storage as well as sending it to
the server. You can set this parameter to any of the following values: none, traces,
traces-fork, logs, logs, all, or all-fork.
The Oracle® Enterprise Session Border Controller uses the value of this parameter in conjunction with the process-log-ip and process-log-port values to determine what information to send. If you have configured the proc-log-ip and proc-log-port parameters, choosing traces sends just the trace information (provided they are turned on), logs sends only process logs (log.*), and all sends everything (which is the default).
Set the log-filter to all-fork for the system to include TCP and TLS traces in logs.
