MSRP Management Monitoring
When you want to see MSRP flow, cumulative, and state counts statistics for the Oracle® Enterprise Session Border Controller (Enterprise SBC), use the show mbcd statistics, show msrp statistics, and show mbcd msrp commands.
The show mbcd statistics command displays MSRP flow counts for the current statistics window. For example:
ORACLE# show mbcd statistics
16:38:49-145
MBCD Status -- Period -- -------- Lifetime --------
Active High Total Total PerMax High
Client Sessions 1 1 0 1 1 1
Flow-MSRP 2 2 0 2 2 2
Flow Rate = 0.0
Load Rate = 0.0
ORACLE#The show msrp statistics command can display the cumulative count for dozens of statistics. The system always displays the default set of statistics, even when the value is zero, plus any other statistics that do have a value. For example:
ORACLE# show msrp statistics
FD Table Size: 0
Session-ID Table Size: 0
Total Active Sessions: 0
Maximum Active Sessions: 0
Total Established Sessions: 0
Total Provisioned Sessions: 0
Total Finished Sessions: 0
Total Accepted Connections: 0
Total Connected Connections: 0
Total Released Connections: 0
Total Requests Received: 0
Total Requests Sent: 0
Total Responses Received: 0
Total Responses Sent: 0
Total Global Buffer Data: 0
Total MSRP Nat Flows Added: 0
Total MSRP Nat Flows Deleted: 0
Total Active CEMA Sessions: 0
Total Established Sessmatch Sessions: 0
Total Provisioned Sessmatch Sessions: 0
Total Active Sessmatch Sessions: 0
The show mbcd msrp command displays MSRP session state counts. For example:
ORACLE# show mbcd msrp
14:35:15-194
MSRP Statistics ---- Lifetime ----
Recent Total PerMax
Provision Sessions Unreleased 0 0 0
Listening Sessions Unreleased 0 0 0
Established Sessions Unreleased 0 0 0
Closed Sessions Unreleased 0 0 0
Finished Sessions Unreleased 0 0 0
PPM Messages Received 0 0 0
PPM Messages Processed 0 0 0
PPM Messages Sent 0 0 0
PPM Messages Send Fail 0 0 0
MSRP Flow States -- Period -- -------- Lifetime --------
MSRP-FlowListen 0 0 0 0 0 0
MSRP-FlowProvision 0 0 0 0 0 0
MSRP-FlowProvisioned 0 0 0 0 0 0
MSRP-FlowEstablished 0 0 0 0 0 0
MSRP-FlowShared 0 0 0 0 0 0
MSRP-FlowClose 0 0 0 0 0 0
MSRP-FlowFinished 0 0 0 0 0 0
MSRP-FlowReleased 0 0 0 0 0 0
MSRP-FlowWaitDrop 0 0 0 0 0 0
You can configure the system to extend the show mbcd msrp output. After configuration, the system provides additional arguments. The additional arguments provide a broad set of system-wide or realm-based statistics, and include SEND and REPORT statistics. See "Extended MSRP Statistics" in the Configuration Guide and "MSRP Protocol Performance" in the Maintenance and Troubleshooting Guide for more information, including configuration.
