Minimum Virtual Machine Resource Configurations
The ISR virtual hosts have the following default VM configurations:
Configuration Type | RSS | Index | Dashboard | FACE API |
VM Version | 8 | 8 | 8 | 8 |
CPU | 4 vCPU | 4 vCPU | 1 vCPU | 1 vCPU |
Memory | 16GB | 8GB | 2GB | 2GB |
Disk Provisioning Type | Thin | Thin | Thin | Thin |
Disk Provisioned Size | 256GB* | 256GB* | 12GB | 12GB |
Network Adapter 1 | Admin | Admin | Admin | Admin |
Network Adapter 2 | Local | Local | Local | Local |
Network Adapter 3 | Voice | Voice | Voice | Voice |
Network Adapter 4 | Data | Data | Data | Data |
WARNING:
The values in the table above reflect the minimum resources required to run the ISR components in a lab/trial environment. For information on your ISR production deployment sizing needs, contact your Oracle representative.Networking Considerations
The
ISR expects four
separate network interfaces for the following functions:
The
Interactive Session Recorder Security Guide covers the
ISR networking
considerations in depth. Oracle recommends reviewing that document before
proceeding with the installation.
Network | Expected Use |
Admin | Management Interface, used for accessing consoles and SNMP traffic |
Local (169.254.1.x) | Used for internal communications between the various ISR components |
Voice | SIP and Media traffic |
Data | Recording Archival and all FACE API traffic |
