2.1 Required Materials
- A target-release TPD ISO (In case IPM is required) and ELAP ISO (for ELAP install/incremental upgrade).
- Optical media – USB flash drive.
- A terminal and null modem cable to establish a serial connection.
- Since RTDB backups of ELAP 10.2 release are not compatible with ELAP 11.X release, in case of fresh installation, SERVDI backup file from LSMS 14.X is required to initialize the RTDB. Copy the backup file to a remote machine.
- Eagle STP login IP, user, and password
- Write down the system configuration information.
Table 2-2 System Configuration Information
Description Information Provisioning IPs and their netmasks
VIP
NTP1 IP
NTP2 IP
NTP3 IP
Provisionable Gateway
Time Zone
Other IPs required and their netmasks
- Passwords for users on the local system:
Table 2-3 User Password Table
ELAP USERS login MPS A password MPS B password elapconfig
elapdev
root
elapall
(needed for GUI access)
MySQL (EuiDB) root user
admusr
