1.5 Definitions
Table 1-2 Table 2: Definitions
| Term | Definition |
Active ELAP |
The ELAP site that is currently used for provisioning through HSOP. |
Standby ELAP |
The ELAP site that is NOT currently used for provisioning through HSOP. |
System health Check |
Procedure used to determine the health and status of the ELAP server, typically performed using the TPD syscheck utility. |
