1.7 Required Materials
Make sure that the LSMS is already migrated to LSMS 14.0 before performing the ELAP migration from ELAP 10.2 to 11.1.x.-
Two (2) target-release TPD USBs.
Two (2) target-release ELAP USBs or a target release ELAP ISO file.
A terminal and null modem cable to establish a serial connection.
Identify if the ELAP pair is connected to the DSM Cards, or a mixture of DSM and SMXG Cards.
Write down the Eagle Cards type.
Type of Eagle Cards: _______________________
System configuration information like NTP Server IP, Provisional IPs etc.
Write down the system configuration information.
Provisionable IPs: _________________________
VIP: _________________________
Provisionable Gateway: _____________________
NTP Server IPs: __________________________ Other IPs required: ________________________
Passwords for users on the local system:
Table 1-5 Table 3: User Password Table
| ELAP USERS | ||
| login | MPS A password | MPS B password |
elapconfig |
elapdev |
syscheck |
root |
elapall (needed for GUI access) |
mysql(EuiDB) root user |
admusr |
