3.5.4 Procedure 14 VERIFY CONFIGURATIONS
Table 3-18 Procedure 14 VERIFY CONFIGURATIONS
STEP# This procedure verifies the E5APPB configurations.Note: Estimated time of completion is 5 minutes.Check off (√) each step as it is completed. Boxes have been provided for this purpose under each step number.Should this procedure fail, Contact Oracle technical services and ask for FULL UPGRADE ASSISTANCE.
1.
MPS A:
Login to serial console as root.
login: root
Password: <root_password>
2.
MPS A:
Switch user to elapconfig.
# su - elapconfig
3.
MPS A:
Enter option 1 to display the current configuration.
ELAP Configuration Menu with option 1 entered to display the configuration.
4.
MPS A:
Verify the configuration data with the data recorded earlier
Press Return to continue.
ELAP A Provisioning Network IP Address = 192.168.59.9
–LAP B Provisioning Network IP Address = 192.168.59.10
Provisioning Network Netmask = 255.255.255.0
Provisioning Network Default Router = 192.168.59.250
Provisioning VIP = 192.168.59.22
ELAP A Sync Network Address = 169.254.1.100
ELAP B Sync Network Address = 169.254.1.200
ELAP A Main DSM Network Address = 192.168.120.100
ELAP B Main DSM Network Address = 192.168.120.200
ELAP A Backup DSM Network Address = 192.168.121.100
ELAP B Backup DSM Network Address = 192.168.121.200
ELAP A HTTP Port = 80
ELAP B HTTP Port = 80
ELAP A HTTPS Port = 443
ELAP B HTTPS Port = 443
ELAP A Banner Connection Port = 8473
ELAP B Banner Connection Port = 8473
ELAP A Static NAT Address = Not configured
ELAP B Static NAT Address = Not configured
ELAP A LSMS Connection Port = 7483
ELAP B LSMS Connection Port = 7483
ELAP A EBDA Connection Port = 1030
ELAP B EBDA Connection Port = 1030
Time Zone = America/New_York
Press return to continue... ...<return>
5. ☐
MPS A:
Enter option e to Exit.
/-----ELAP Configuration Menu----------\
|  1 | Display Configuration             |
|  2 | Configure Network Interfaces Menu |
|  3 | Set Time Zone                     |
|  4 | Exchange Secure Shell Keys        |
|  5 | Change Password                   |
|  6 | Platform Menu                     |
|  7 | Configure NTP Server              |
|  8 | Mate Disaster Recovery            |
|  e | Exit                              |
Enter Choice: e
*Note: If this menu is not exited properly, root access via ssh will not be disabled.
