3.6.2 Procedure 16 RESTORE EUIDB
Now that the Databases have been copied over, it’s time to restore the Databases and start the ELAP application.
HA status of ELAP servers should be Active and Standby . If HA status is not Active/Standby, contact the My Oracle Support by following the instructions in Appendix E.Table 3-20 Procedure 16 RESTORE EUIDB
| STEP # | This procedure migrates the EuiDB database to the E5APPB. Note: Estimated time of completion is 15 minutes. Check off (√) each step as it is completed. Boxes have been provided for this purpose under each step number. Should this procedure fail, Contact Oracle technical services and ask for FULL UPGRADE ASSISTANCE. | |
1. ☐ |
Active ELAP: Login as elapdev. |
2. ☐ |
Active ELAP: Verify that the DB Backup file has been transferred over and its permissions are correct. |
NOTE: The ownership of file should be elapdev:elap. Check and provide the correct ownership of elapdev:elap, if not correct. |
3. ☐ |
Active ELAP: Restore Output is displayed. |
Example:
If LNP_TN_QTY is set to any value other than 756000000, set the proper value:
Check value of
4. ☐ |
Active ELAP: Reset IP Addresses. Login to elapconfig |
Re-Set the IP addresses using elapconfig. (for Prov and NTP, if used).
5. ☐ |
Active ELAP: The ELAP Configuration Menu is displayed.Select option 2 to enter the Network Interfaces Menu. |
6. ☐ |
Active ELAP: The Configure Network Interfaces Menu is displayed. Select option 1 to configure the provisioning network. |
7. ☐ |
Active ELAP: Enter the IP addresses, subnet mask, default gateway and Virtual IP addres, subnet mask, default gateway and Virtual IP tering them again by just pressing enter key). |
Note: The following drbd messages might be observed while configuring provisioning network. They are expected so we can ignore them.
8. ☐ |
Active ELAP: Select option e to exit. |
9. ☐ |
Active ELAP: If configured, change “Pretty Name” to change the name on the ELAP GUI. |
10. ☐ |
Active ELAP: Switch user to elapconfig and verify the configurations. |
Verify the configurations using the uiEdit command. |
11. ☐ |
Active ELAP: Note down the timestamp in log. |
Run the following command:
This procedure is complete!
