| 1. |
MPS X: Login as elapdev
login: elapdev password: <elapdev_password> |
| 2. |
MPS X: Record and verify the system configuration Select Option 1 from elapconfig menu.
$ sudo su - elapconfig
| 3. |
MPS X: Record and verify the ntp configuration Select Option 7 from elapconfig menu and then Option 1 from ELAP Configure NTP Server Menu.
| 4. |
MPS X:Exit from elapconfig menu
| 5. |
MPS X: Record /etc/hosts configuration
$ cat /etc/hosts
Do not modify this file by hand. Refer to Tekelec Configuration
documentation.
The order of the aliases in this file is significant to the installation process.
127.0.0.1 localhost loghost Floater-3-prova-bkup mate-provb-bkup
192.168.120.100 dsmm-a
192.168.121.100 dsmb-a
192.168.120.200 dsmm-b
192.168.121.200 dsmb-b
169.254.1.200 mate sync-b hasync-1a
169.254.1.100 sync-a hasync-1b
192.168.123.100 dsmvip-a
192.168.123.200 dsmvip-b
169.254.1.201 mate-ipdptp0 server_ppp0
169.254.1.202 mate-ppp client_ppp0
169.254.1.101 Floater-3-ipdptp0 server_ppp1
169.254.1.102 Floater-3-ppp client_ppp1
169.254.1.1 switch1A
169.254.1.2 switch1B
10.75.124.247
10.75.141.107 Floater-3 prova-ip
10.75.141.108 mate-prov provb-ip Floater-4
10.75.141.109 prov-vip
| 6. |
MPS X: Verify and Record IPs configured on each interface.
$ ifconfig -a
bond0 Link encap:Ethernet HWaddr 00:00:17:0E:A6:9F
inet6 addr: fe80::200:17ff:fe0e:a69f/64 Scope:Link
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:1929134 errors:0 dropped:0 overruns:0 frame:0
TX packets:19001949 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:144187191 (137.5 MiB) TX bytes:28087840989 (26.1 GiB)
bond0.1 Link encap:Ethernet HWaddr 00:00:17:0E:A6:9F
inet addr:169.254.1.100 Bcast:169.254.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1916373 errors:0 dropped:0 overruns:0 frame:0
TX packets:1366320 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:116466961 (111.0 MiB) TX bytes:26923908883 (25.0 GiB)
bond0.3 Link encap:Ethernet HWaddr 00:00:17:0E:A6:9F
inet addr:192.168.121.100 Bcast:192.168.121.255 Mask:255.255.255.0
RX packets:12253 errors:0 dropped:0 overruns:0 frame:0
TX packets:12246 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:685938 (669.8 KiB) TX bytes:681040 (665.0 KiB)
bond1 Link encap:Ethernet HWaddr B2:69:BB:E5:71:36
BROADCAST MASTER MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
bond2 Link encap:Ethernet HWaddr 7E:7E:C9:9E:5E:FA
bond3 Link encap:Ethernet HWaddr EE:AC:C5:EC:28:BE
eth01 Link encap:Ethernet HWaddr 00:00:17:0E:A6:A1
inet addr:10.75.141.47 Bcast:10.75.141.127 Mask:255.255.255.128
inet6 addr: 2606:b400:605:b917:200:17ff:fe0e:a6a1/64 Scope:Global
inet6 addr: fe80::200:17ff:fe0e:a6a1/64 Scope:Link
RX packets:8390156 errors:0 dropped:0 overruns:0 frame:0
TX packets:7898637 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1310423076 (1.2 GiB) TX bytes:724420390 (690.8 MiB)
Memory:fdee0000-fdefffff
eth02 Link encap:Ethernet HWaddr 00:00:17:0E:A6:A0
inet addr:192.168.120.100 Bcast:192.168.120.255 Mask:255.255.255.0
inet6 addr: fe80::200:17ff:fe0e:a6a0/64 Scope:Link
RX packets:12250 errors:0 dropped:0 overruns:0 frame:0
TX packets:12255 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:857300 (837.2 KiB) TX bytes:681418 (665.4 KiB)
Memory:fde60000-fde7ffff
eth03 Link encap:Ethernet HWaddr 00:00:17:0E:A6:9F
UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1
Memory:fdfe0000-fdffffff
eth04 Link encap:Ethernet HWaddr 00:00:17:0E:A6:9F
UP BROADCAST SLAVE MULTICAST MTU:1500 Metric:1
Memory:fdf60000-fdf7ffff
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1605595 errors:0 dropped:0 overruns:0 frame:0
TX packets:1605595 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:106538690 (101.6 MiB) TX bytes:106538690 (101.6 MiB)
lo:1 Link encap:Local Loopback
inet addr:192.168.123.100 Mask:255.255.255.0
| 7. |
MPS X: Record EuiDB settings
$ uiEdit
"LNP_ENABLED" is set to "TRUE"
"Alarms_Purged_Nb_Days" is set to "30"
"new_user_default_groups" is set to "readonly"
"max_passwd_age" is set to "60"
"EBDAD_LSMS_PORT" is set to "1030"
"max_concurrent_user_logins" is set to "1"
"ELAP_A_DSM_LPBK_NETWORK_ADDRESS" is set to "192.168.123.100"
"max_concurrent_logins" is set to "20"
"ELAP_A_NAME" is set to "Floater-3"
"ELAP_RELEASE" is set to "10.1.1"
"ELAP_LOGGING_REMOTE_USERNAME" is set to ""
"ELAP_A_SYNCH_NETWORK_ADDRESS" is set to "169.254.1.100"
"AUTO_RTDB_BKUP_FILEPATH" is set to "/var/TKLC/elap/free/backup/"
"HTTP_ENABLED" is set to "No"
"ELAP_A_PRETTY_NAME" is set to "ELAP_A_NAME"
"AUTO_RTDB_BKUP_FILES_TO_MANTAIN" is set to "5"
"session_idle_timeout" is set to "10"
"ELAP_B_PROV_NETWORK_IP_ADDRESS" is set to "10.75.141.108"
"EXINIT_DEBUG_LEVEL" is set to "OFF"
"SNAPPER_ROLLBACK_INTERVAL" is set to "900"
"EBDAD_DEBUG_LEVEL" is set to "OFF"
"MAINT_DEBUG_NUM_LOGS" is set to "5"
"RIDB_LV_PATH" is set to "/dev/vgdrbd0"
"PROV_DEBUG_NUM_LOGS" is set to "5"
"LNPTRANS_LOG_DAYS" is set to "7"
"EXINIT_DEBUG_NUM_LOGS" is set to "5"
"ELAP_A_HTTP_PORT" is set to "80"
"EXINIT_ERROR_NUM_LOGS" is set to "5"
"logon_msg" is set to "NOTICE: This is a private computer system. Unauthorized access or use may lead to prosecution."
"ELAP_B_HTTPS_PORT" is set to "443"
"ELAP_B_NAME" is set to "Floater-4"
"AUTO_RTDB_BKUP_TIME" is set to "6:00"
"EBDAD_GS_PORT" is set to "9692"
"LNP_LRN_QTY" is set to "150000"
"BACKUP_FILE_DIR" is set to "/var/TKLC/elap/free/backup"
"ELAP_LOGGING_EXPORT" is set to "DISABLED"
"AUTO_RTDB_BKUP_FREQUENCY" is set to "1"
"PROVISIONING_NETWORK_NETMASK" is set to "255.255.255.0"
"ELAP_LOGGING_REMOTE_SFTP_PATH" is set to ""
"ELAP_B_SYNCH_NETWORK_ADDRESS" is set to "169.254.1.200"
"ELAP_A_HTTPS_PORT" is set to "443"
"ELAP_A_DSM_MAIN_NETWORK_ADDRESS" is set to "192.168.120.100"
"ELAP_A_SUEXEC_HTTPS_PORT" is set to "8002"
"ELAP_A_GS_BANNER_PORT" is set to "8473"
"ELAP_B_DSM_BACKUP_NETWORK_ADDRESS" is set to "192.168.121.200"
"MAINT_DEBUG_LEVEL" is set to "OFF"
"DOWNLOAD_FILE_DIR" is set to "/var/TKLC/elap/free/backup"
"euidb_version" is set to "3"
"LNP_NPANXX_QTY" is set to "300000"
"LSMS_PROVISIONING" is set to "OFF"
"ELAP_LOGGING_TIME_FORMAT" is set to "UTC"
"MAINT_ERROR_NUM_LOGS" is set to "5"
"UI_IP_AUTHORIZATION_ENABLED" is set to "FALSE"
"ELAP_LOGGING_REMOTE_IP_ADDRESS" is set to ""
"AUTO_RTDB_BKUP_DELETE_OPTION" is set to "y"
"HSOPD_ERROR_NUM_LOGS" is set to "5"
"TRPD_ERROR_NUM_LOGS" is set to "5"
"apache_403_error_message" is set to "NOTICE: This workstation is not authorized to access the GUI."
"EBDAD_ERROR_NUM_LOGS" is set to "5"
"max_account_inactivity" is set to "0"
"HSOPD_DEBUG_LEVEL" is set to "OFF"
"TRPD_DEBUG_NUM_LOGS" is set to "5"
"ELAP_LOGGING_REMOTE_PASSWORD" is set to ""
"ELAP_B_HTTP_PORT" is set to "80"
"MATE_MPS_HTTPS_PORT" is set to "443"
"EBDAD_DEBUG_NUM_LOGS" is set to "5"
"ELAP_B_PRETTY_NAME" is set to "ELAP_B_NAME"
"HSOPD_LSMS_PROVISIONING_PORT" is set to "7483"
"ELAP_RIDB_RELEASE" is set to "10.0.0"
"SNAPPER_LOG_LEVEL" is set to "4"
"AUTO_RTDB_BKUP_TYPE" is set to "local_mate"
"PROV_ERROR_NUM_LOGS" is set to "5"
"ELAP_A_PROV_NETWORK_IP_ADDRESS" is set to "10.75.141.107"
"CNF_QTY_THRESHOLD_PERC" is set to "90"
"MATE_MPS_HTTP_PORT" is set to "80"
"passwd_reuse_limit" is set to "12"
"apache_403_error_message_default" is set to "NOTICE: This workstation is not authorized to access the GUI."
"HTTPS_ENABLED" is set to "Yes"
"HSOPD_DEBUG_NUM_LOGS" is set to "5"
"ELAP_B_DSM_MAIN_NETWORK_ADDRESS" is set to "192.168.120.200"
"LOCAL_PROVISIONING_VIP" is set to "10.75.141.109"
"TRPD_DEBUG_LEVEL" is set to "OFF"
"RTDB_AUDIT" is set to "ON"
"LNP_TN_QTY" is set to "96000000"
"ELAP_B_GS_BANNER_PORT" is set to "8473"
"PROV_DEBUG_LEVEL" is set to "OFF"
"RELOAD_FLOW_CONTROL_TIME" is set to "200"
"passwd_complexity_checking" is set to "on"
"LNP_MR_QTY" is set to "2000000"
"RTDBA_NUM_LOGS" is set to "5"
"PROVISIONING_NETWORK_DEFAULT_ROUTER" is set to "10.75.141.1"
"RIDB_LV_NAME" is set to "lnpdb"
"ELAP_A_SUEXEC_HTTP_PORT" is set to "8001"
"ELAP_B_SUEXEC_HTTPS_PORT" is set to "8002"
"LNP_LRNMR_QTY" is set to "2000000"
"ELAP_LOGGING_ENHANCEMENTS_FEATURE" is set to "OFF"
"ELAP_A_DSM_BACKUP_NETWORK_ADDRESS" is set to "192.168.121.100"
"HSOPD_GS_PORT" is set to "9691"
"ELAP_B_SUEXEC_HTTP_PORT" is set to "8001"
"ELAP_B_DSM_LPBK_NETWORK_ADDRESS" is set to "192.168.123.200"
"max_failed_logins" is set to "3"
"BULK_DOWNLOAD" is set to "ON"
| 8. |
MPS X: Verify lnpdb logical volume.
$ su – admusr
$ Password:<admusr_password>
$ sudo lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
lnpdb vgdrbd0 owi-aos--k 2.50g
mysql vgdrbd0 -wi-ao---k 6.00g
rollbacksnap vgdrbd0 sri-a-s--- 2.50g lnpdb 0.00
drbdmeta vgroot -wi-ao---- 128.00m
elaproot vgroot -wi-ao---- 4.00g
free vgroot -wi-ao---- 196.97g
logs vgroot -wi-ao---- 40.00g
plat_root vgroot -wi-ao---- 1.00g
plat_swap vgroot -wi-ao---- 1.97g
plat_tmp vgroot -wi-ao---- 1.00g
plat_usr vgroot -wi-ao---- 4.00g
plat_var vgroot -wi-ao---- 1.00g
plat_var_tklc vgroot -wi-ao---- 4.00g
$ exit
| 9. |
MPS X: Verify operational status of ELAP software.
$ service Elap status
~~ /etc/init.d/Elap status ~~
process hsopd is running.
process ebdad is running.
process maint is running.
process prov is running.
process trpd is running.
ELAP application is running
| 10. |
MPS X: Verify HA status
$ hastatus; ssh mate hastatus
ACTIVE
STANDBY
| 11. |
MPS X: Record cron file configuration
$ cat /etc/cron.d/TS.EXAP
# Task Scheduler cron file for EXAP
# WARNING: This file is automatically generated. Do not manually edit it.
SHELL=/bin/bash
MAILTO=""
# BEGTYPE=ELAPLOGGING
# ID=LOGSRMCP, Action="/usr/TKLC/elap/bin/removeCompressLogs", Sched="daily,1,00:01"
01 00 * * * elapdev /usr/TKLC/elap/bin/removeCompressLogs
# ID=LOGSSFTP, Action="/usr/TKLC/elap/bin/transferLogsToRemote", Sched="hourly,1,00"
00 * * * * elapdev /usr/TKLC/elap/bin/transferLogsToRemote
# ENDTYPE
# BEGTYPE=AUTOBKPNOTCFD
# ID=1, Action="/usr/TKLC/elap/bin/raiseAlarmAutoBkpNotConfgd.pl", Sched="minutely,5"
*/5 * * * * elapdev /usr/TKLC/elap/bin/raiseAlarmAutoBkpNotConfgd.pl
# ENDTYPE
# BEGTYPE=AUTO_RTDB_BCKP
# ID=1, Action="/usr/TKLC/elap/bin/autoBackupRtdb.sh", Sched="daily,1,06:00"
00 06 * * * elapdev /usr/TKLC/elap/bin/autoBackupRtdb.sh
# ENDTYPE
# BEGTYPE=HTTPSDISABLE
# ID=1, Action="/usr/TKLC/elap/bin/raiseBnrMsgHttpsDisable.pl", Sched="hourly,12,00"
00 */12 * * * elapdev /usr/TKLC/elap/bin/raiseBnrMsgHttpsDisable.pl
# ENDTYPE
| 12. |
MPS X: Record /etc/passwd file
$ cat /etc/passwd
root:x:0:0:root:/root:/bin/bash
bin:x:1:1:bin:/bin:/sbin/nologin
daemon:x:2:2:daemon:/sbin:/sbin/nologin
adm:x:3:4:adm:/var/adm:/sbin/nologin
lp:x:4:7:lp:/var/spool/lpd:/sbin/nologin
sync:x:5:0:sync:/sbin:/bin/sync
shutdown:x:6:0:shutdown:/sbin:/sbin/shutdown
halt:x:7:0:halt:/sbin:/sbin/halt
mail:x:8:12:mail:/var/spool/mail:/sbin/nologin
uucp:x:10:14:uucp:/var/spool/uucp:/sbin/nologin
operator:x:11:0:operator:/root:/sbin/nologin
games:x:12:100:games:/usr/games:/sbin/nologin
gopher:x:13:30:gopher:/var/gopher:/sbin/nologin
ftp:x:14:50:FTP User:/var/ftp:/sbin/nologin
nobody:x:99:99:Nobody:/:/sbin/nologin
dbus:x:81:81:System message bus:/:/sbin/nologin
admusr:x:4996:4996:Platform remote admin user:/home/admusr:/bin/bash
rpc:x:32:32:Rpcbind Daemon:/var/cache/rpcbind:/sbin/nologin
nscd:x:28:28:NSCD Daemon:/:/sbin/nologin
vcsa:x:69:69:virtual console memory owner:/dev:/sbin/nologin
apache:x:48:48:Apache:/var/www:/sbin/nologin
sshd:x:74:74:Privilege-separated SSH:/var/empty/sshd:/sbin/nologin
ntp:x:38:38::/etc/ntp:/sbin/nologin
saslauth:x:499:76:Saslauthd user:/var/empty/saslauth:/sbin/nologin
postfix:x:89:89::/var/spool/postfix:/sbin/nologin
platcfg:x:5000:5000:Platform Configuration User:/home/platcfg:/usr/TKLC/plat/bin/platcfg
tpdProvd:x:5010:5010:TPD Provisioning Daemon:/home/tpdProvd:/usr/bin/false
syscheck:x:71:71:System Health Check User:/home/syscheck:/usr/TKLC/plat/bin/run_syscheck
hids:x:4995:4995:HIDS admin user:/home/hids:/sbin/nologin
dhcpd:x:177:177:DHCP server:/:/sbin/nologin
nslcd:x:65:55:LDAP Client User:/:/sbin/nologin
rtkit:x:498:450:RealtimeKit:/proc:/sbin/nologin
rpcuser:x:29:29:RPC Service User:/var/lib/nfs:/sbin/nologin
nfsnobody:x:65534:65534:Anonymous NFS User:/var/lib/nfs:/sbin/nologin
named:x:25:25:Named:/var/named:/sbin/nologin
tcpdump:x:72:72::/:/sbin/nologin
mysql:x:497:449:MySQL server:/var/TKLC/elap/db:/bin/bash
elapdev:x:3000:6001:elapdev user:/home/elapall:/bin/bash
elap:x:3006:6001:elap no login user:/home/elapall:/sbin/nologin
elapconfig:x:3002:6001:elapconfig user:/home/elapconfig:/home/elapconfig/runrunUI
appuser:x:3004:6002:appuser user for viewing log files from the GUI:/usr/TKLC/elap/logs:/bin/rbash
| 13. |
MPS X: Backup the EuiDB.
| 14. |
MPS X: Verify backups are being taken properly.
$ ls -ltrh /var/TKLC/appl/free/npdbBackup_ELAP21_20170719174539.tar
-rw-r----- 1 root root 220K Jul 19 12:05 /var/TKLC/appl/free/npdbBackup_ELAP21_20170719174539.tar
| 15. |
MPS X: Gather application log files.
$ sudo savelogs –all Logs will be save in /var/TKLC/elap/free/ directory $ ls -ltrh /var/TKLC/elap/free/
-rw-r----- 1 elapdev elap 2.6M Jul 18 17:13 /var/TKLC/elap/free/logsCapture_ELAP21_20170718171310.tar.bz2
| 16. |
MPS X: Gather system log files.
$ su – admusr
$ Password: <admusr_password>
$ sudo /usr/TKLC/plat/sbin/savelogs_plat Logs will be saved in /tmp directory /tmp/savelogs_plat.Natal-A.10689.tar.bz2
$ exit
| 17. |
MPS X: Verify RTDB status from GUI. From GUI select “RTDB->View RTDB status” Verify that RTDB status on ELAP is coherent which indicates that LSMS and ELAP are in sync.
| 18. |
MPS X: Verify DMS DB levels matched and DB status is coherent on all STP cards From ELAP GUI banner, click on notepad icon beside EAGLE.
| 19. |
MPS X: Verify DB status on DSM cards and that their provisioning system is taking updates.
Login to EAGLE and run command: rept-stat-db:display=all
Command Accepted - Processing
eagle2 17-07-27 13:54:12 EST EAGLE 46.6.0.0.0-71.5.0
Command entered at terminal #2.
eagle2 17-07-27 13:53:49 EST EAGLE 46.6.0.0.0-71.5.0
DATABASE STATUS: >> OK <<al #2.
TDM 1114 ( STDBY) TDM 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 54 17-07-24 12:43:00 EST Y 54 17-07-24 12:43:00 EST
FD CRNT Y 111 Y 111
GTT DB 4 4
MCAP 1113 MCAP 1115 0
RD BKUP - - - - - - - - .
USB BKP - - - - - - - -
CARD/APPL LOC C T LEVEL TIME LAST UPDATE EXCEPTION
IPSG 1102 - - - - - -
CCS7ITU 1103 - - - - - -
EROUTE 1104 - - - - - -
IPS 1105 - - - - - -
OAM-RMV 1113 - - - - - -
TDM-CRNT 1114 Y N 111 17-07-26 16:01:42 -
TDM-BKUP 1114 Y - 54 17-07-21 13:14:02 DIFF LEVEL
OAM-RMV 1115 - - - - - -
OAM-USB 1115 - - - - - -
TDM-CRNT 1116 Y N 111 17-07-26 16:01:42 -
TDM-BKUP 1116 Y - 54 17-07-21 13:14:02 DIFF LEVEL
CCS7ITU 1201 Y N 111 17-07-26 16:01:42 -
ATMANSI 1202 - - - - - -
ATMITU 1203 - - - - - -
CCS7ITU 1204 Y N 111 17-07-26 16:01:42 -
CCS7ITU 1205 - - - - - -
CCS7ITU 1207 - - - - - -
ATMITU 1216 - - - - - -
VSCCP 1217 Y N 111 17-07-26 16:01:42 -
ELAP A ( ACTV )
C BIRTHDATE LEVEL EXCEPTION
RTDB Y 17-03-23 14:34:12 17 -
RTDB-EAGLE 17-03-23 14:34:12 17 -
ELAP B ( STDBY )
EAGLE RTDB REPORT
CARD/APPL LOC C BIRTHDATE LEVEL EXCEPTION IN-SRVC
VSCCP 1217 Y 17-03-23 09:04:12 17 - 1d 1h 50m
| 20. |
MPS X: Verify alarms present on STP cards.
Run following command on EAGLE to check alarms rept-stat-alm
eagle2 17-07-27 13:55:19 EST EAGLE 46.6.0.0.0-71.5.0
rept-stat-alm
eagle2 17-07-27 13:55:20 EST EAGLE 46.6.0.0.0-71.5.0
ALARM TRANSFER= RMC
ALARM MODE CRIT= AUDIBLE MAJR= AUDIBLE MINR= AUDIBLE
ALARM FRAME 1 CRIT= 11 MAJR= 36 MINR= 19
ALARM FRAME 2 CRIT= 0 MAJR= 0 MINR= 0
ALARM FRAME 3 CRIT= 0 MAJR= 0 MINR= 0
ALARM FRAME 4 CRIT= 0 MAJR= 0 MINR= 0
ALARM FRAME 5 CRIT= 0 MAJR= 0 MINR= 0
ALARM FRAME 6 CRIT= 0 MAJR= 0 MINR= 0
PERM. INH. ALARMS CRIT= 0 MAJR= 0 MINR= 0
TEMP. INH. ALARMS CRIT= 0 MAJR= 0 MINR= 0
TIMED INH. ALARMS CRIT= 0 MAJR= 0 MINR= 0
ACTIVE ALARMS CRIT= 11 MAJR= 36 MINR= 19
TOTAL ALARMS CRIT= 11 MAJR= 36 MINR= 19
Command Completed.
