C.2 Copying File Using USB
Table C-2 Copying File Using USB
STEP # This procedure will help copying the license file from a desktop to LSMS server
☐1.
Server X: Copy license file to USB
Connect USB to desktop and copy the license file from desktop to USB.
☐2.
LSMS MPS: Confirm how the USB is enumerated on LSMS server
Connect the USB to LSMS MPS which contains the license file and check on how it is enumerated using command :
$dmesg | grep -i "removable disk"
Expected output
sd 6:0:0:0: Attached scsi removable disk sdc
This shows USB is enumerated as /dev/sdc.
☐3.
LSMS MPS: Determine the partition name
Run command fdisk –l on enumerated name device to determine partition name :
$fdisk –l /dev/sdc
Expected Output :
Disk /dev/sdc: 2013 MB, 2013265920 bytes
256 heads, 63 sectors/track, 243 cylinders
Units = cylinders of 16128 * 512 = 8257536 bytes
Device Boot	Start	End	Blocks	Id System
/dev/sdc1	*	1	110	887008+	b W95 FAT32
This shows that partition name is /dev/sdc1
☐4.
LSMS MPS: Copy license file from USB to MPS
Run below command to copy the license file from USB
$mkdir –p /tmp/usb
$ mount /dev/sdc1 /tmp/usb
☐5.
LSMS MPS: Copy license file from /tmp directory
$ cp /tmp/usb/<license-file> /usr/local/netech/etc/license
☐6.
LSMS MPS: Check if the license file has been copied correctly
Run command to check for license file:
$ cat /usr/local/netech/etc/license
Expected Output:
Contents of license file should be displayed
☐7.
LSMS MPS: Unmount the USB
Unmount the USB using command:
$umount /tmp/usb
This procedure is complete!
