1 Installing ASR 70 on MetaSolv Solution 8.0
This chapter explains how to install Access Service Request (ASR) 70 on MetaSolv Solution 8.0.
Pre-Installation Checklist
Ensure the following:
  • You have installed MetaSolv Solution 8.0.
  • The following environmental variables are set:
    PATH={jdk21}/bin:$PATH
    JAVA_HOME={jdk21}
    MW_HOME= {Oracle_Home}
    where
    • {jdk21} is the location where you installed JDK 21.
    • {Oracle_Home} is the directory location where Oracle Fusion Middleware (14.1.2) components are installed. This directory contains the base directory for WebLogic Server.
Installing ASR
To install ASR:
  1. From MSLV_Home, enter the following command:
    java -jar Asr.R70_0_0.buildNo_M80.jar
    where:
    • MSLV_Home is the directory in which the MetaSolv Solution software is installed.
    • buildNo is the build number that contains the ASR installer.
    For example:
    java -jar Asr.R70_0_0.b32_M80.jar
    The Select MetaSolv home directory window appears.
  2. From the Look In list, click the down arrow and select a directory in which the installation program files can be stored and used during the installation process, and then click Select.
    A directory named asr70installer is automatically created in the selected directory. Oracle recommends choosing your MSLV_Home directory for this task. MSLV_Home is the directory in which the MetaSolv Solution software is installed.
    The installation program automatically launches the installation process by invoking setup.sh (UNIX/Linux) or setup.cmd (Windows) in the MSLV_Home/asr70installer directory.
    The welcome screen for the MetaSolv Solution ASR installation appears.
  3. Click Next.
    The Details window appears.
  4. Enter the path and name of the MetaSolv Home directory, MetaSolv Domain directory, and MetaSolv Server directory or click Open to search for the directories.
  5. Click Next.
    The Install Type window appears.
  6. Select any one of the following installation types:
    • Install all ASR Files
    • Install Only ASR EAR File
    When prompted for the Install Type, if the environment is a clustered environment, you can choose an option to extract the .EAR file only. Use this option to extract the .EAR file on the administration server for deployment to separate managed servers. For a non-clustered environment, choose the option to install and deploy all files.
  7. Click Next.
    The Install Summary window appears.
  8. Click Finish.
  9. Restart the application server.
    If there are multiple servers running in the domain, all servers should be restarted before deploying the application from the Management Console.
    If there are multiple servers running in the domain, you must run the ASR installation for each server instance.
  10. Continue with the procedures in "Applying the Contents of the Stored Procedures and Prodfixsql Directories".
To apply the contents of the stored procedures and prodfixsql directories:
  1. Run the pfixSQL_Master.sql file located in the MSLV_Home/server/appserver/sql/ASR70/prodfixsql directory that was created during the install to apply the contents of the ASR prodfixsql directory to the database.
    where:
    • server is the name of the WebLogic Server.
    The pfixSQL_Master.sql script calls all of the other SQL scripts delivered in the directory.
  2. Run the asr_master.sql file located in the MSLV_Home/server/appserver/sql/ASR70/procs directory that was created during the installation to apply the contents of the ASR procs directory to the database.
    The asr_master.sql file creates or replaces a series of stored procedures used in Ordering and Billing Forum (OBF) validation. These validations are for the Access Services Ordering Guidelines (ASOG) 69 and ASOG 70 versions. MetaSolv Solution created the single asr_master.sql script to call all of the other SQL scripts delivered in the directory.
  3. Run the asr_audit_master.sql file located in the MSLV_Home/server/appserver/sql/ASR70/procs directory that was created during the installation to apply the contents of the ASR procs directory to the database.
    The asr_audit_master.sql file creates or replaces a series of stored procedures and triggers used in capturing the audit and supplement history for ASR orders.
  4. Run DBHealth to recompile all invalid objects.
To run a higher ASR version on a computer that runs a lower version, you must apply the stored procedures and prodfixsql of the higher version.
For example, you may run ASR 70 on a computer where you installed an ASR 69 service pack and applied the associated stored procedures and prodfixsql. To run ASR 70 effectively, you must apply the stored procedures and prodfixsql for ASR 70 to override those that you applied for the ASR 69 service pack.
Deploying ASR on the Application Server in a Single Server Environment
Deploying ASR on the application server in a single server environment involves the following steps:
Undeploying the Existing ASR Application from the Application Server
If you are installing an ASR70 patch or have ASR70 already deployed, undeploy the existing ASR from the application server.
To undeploy the existing ASR from the application server:
  1. Start the WebLogic Server Remote Console
  2. In the Monitoring Tree, go to Deployments, then Application Management.
  3. Select ASR70.
  4. From the Stop list, select Force Stop Now.
    Ensure that the state of the ASR 70 application has changed from Active to Prepared.
  5. In the Edit Tree, go to Deployments, then App Deployments.
  6. Select ASR70 and click Delete.
    The ASR 70 application is undeployed along with the ASR 70 Web Services.
  7. Click Shopping Cart, and then click Commit Changes.
Deploying ASR Application on the Application Server
Before you deploy ASR, ensure that the following server is running:
  • Administration server
    If it is not running, start it using the following startup script:
    For UNIX:
    domain_directory/startServerName.sh
    For Windows:
    domain_directory/startServerName.cmd
    where:
    • domain_directory is the WebLogic Server domain directory.
    • ServerName is the name of the administration server.
To deploy ASR on the application server:
  1. Start the WebLogic Remote Console
  2. In the Edit Tree, go to Deployments, then App Deployments.
  3. Select New.
  4. Enter a name for the application.
  5. In Targets, select the servers to which you want to deploy the ASR70 application.
  6. In Source, navigate to the directory from which you want to deploy ASR 70 (for example, opt/metasolv/mslv01/appserver/deploy), select ASR70.ear.
  7. On Deployment, select Start Application
  8. Click Create.
  9. In Shopping Cart, click Commit Changes.
  10. In the Monitoring Tree, go to Deployments, then Application Management. Ensure that the state of the ASR 70 application has changed from Prepared to Active, which indicates that the ASR 70 application has been deployed along with the ASR 70 Web Services.
Deploying ASR on the Application Server in a Clustered Environment
If the administration server for the domain is on a machine where no managed server process is running, you can run the ASR installer and select the option to only extract the .EAR file. The .EAR file must reside on the machine where the administration server is running in order to deploy to the managed servers in the domain.
Deploying ASR on the application server in a clustered server environment involves the following steps:
  3. Select cluster-ASR70.
  6. Select cluster-ASR70 and click Delete.
Before you deploy ASR, ensure that the following servers are running:
    For UNIX:
    domain_directory/startAdminServer.sh
    For Windows:
    domain_directory/startAdminServer.cmd
    where domain_directory is the WebLogic Server domain directory.
  • Managed server or servers
    Start any managed servers that are not running using the following startup script:
    For UNIX:
    For Windows:
    where:
  3. Select New.
  5. In Targets, select the cluster server to which you want to deploy the ASR70 application.
  6. In Source, navigate to the directory from which you want to deploy ASR 70 (for example, opt/metasolv/mslv01/appserver/deploy), select cluster-ASR70.ear.
  8. Click Create.
  10. In the Monitoring Tree, go to Deployments, then Application Management.Ensure that the state of the ASR 70 application has changed from Prepared to Active, which indicates that the ASR 70 application has been deployed along with the ASR 70 Web Services.
