2 SDH UIM Integration Cartridge
This chapter provides information on the Oracle Communications Network Integrity SDH UIM Integration cartridge.
Overview
This section provides an overview of the Oracle Communications Network Integrity SDH UIM Integration cartridge.
This section contains the following sections:
- About the SDH UIM Integration cartridge
About Cartridge Dependencies
Opening the Cartridge Files in Design Studio
Building and Deploying the Cartridge
About the SDH UIM Integration Cartridge
The SDH UIM Integration cartridge supports modeling of SDH connectivities such as Topological Link, Trail, and Tunnel. It also supports modeling of service managing these connectivities.
The SDH UIM Integration cartridge provides the following:
- Import: Retrieves the SDH connectivities, service, and circuit information from UIM and models them in the Oracle Communications Information Model.
- Perform Incremental Import along with the notifications in the database.
- Discrepancy Detection: Compares the imported UIM data with discovered SDH connectivities and service and reports any differences.
- Resolution: Resolves discrepancies on connectivities, service, and circuits by correcting entities, associations, and attributes in UIM.
This section provides information on dependencies that the SDH UIM Integration cartridge has on other entities.
Run-Time Dependencies
This cartridge requires that the Address_Handlers and SDH_Discovery cartridges are deployed to Network Integrity. UIM must also be installed and be accessible to Network Integrity.
The following components must be deployed in UIM:
- ora_ni_uim_device_ports_interfaces_connectors
- ora_ni_uim_sdh_optical
- SDH_Service_Model
- UIM Integration Web Service
Design-Time Dependencies
The SDH UIM Integration cartridge has the following dependencies:
- Optical_Model
- NetworkIntegritySDK
- SDH_Service_Model
- ora_uim_model
- UIM_Integration_Cartridge
- SDH_Discovery_Cartridge
See Network Integrity UIM Integration Cartridge Guide for information about the operation of the web service and its dependencies.
To review and extend the SDH UIM Integration cartridge, you must download the Oracle Communications SDH UIM Integration Cartridge software from the Oracle software delivery web site: https://edelivery.oracle.com
The software contains the SDH UIM Integration cartridge ZIP file, which has the following structure:
\UIM_Cartridge_Projects\
\Network_Integrity_Cartridge_Projects\
See Design Studio Help and Network Integrity Developer's Guide for information about opening files in Design Studio.
See Design Studio Help for information about building and deploying cartridges.
About the Cartridge Components
This section provides information about the components of Oracle Communications Network Integrity SDH UIM Integration cartridge.
The SDH UIM Integration Cartridge contains the following actions:
- Abstract Optical Import from UIM
- Import SDH Connectivity and Service from UIM
- Incremental Import SDH Connectivity and Service from UIM
- Detect Discrepancies for SDH Connectivity and Service
- Resolve SDH Connectivity and Service into UIM
Abstract SDH Service Actions
The Abstract SDH Service Actions is an abstract action that interacts with UIM to fetch the devices associated with SDH connectivities and model the Service.
Scan Parameter Group
The Abstract SDH Service Actions action contains the following scan parameter groups:
- SDH Import Parameters
Table 2-1 SDH Import Parameters
| Parameter | Default Value | Mandatory | Description |
| Circle Name | N/A | No | The Circle Name of the OSS. |
| Device Name | N/A | No | Import Devices with the names provided in this input field. |
| Device Name File | N/A | No | Import Devices with the names in the file path provided in this input field. |
| Logical Device Specification | N/A | No | Import Devices with the specification provided in this input field. |
| Service | N/A | No | Select this checkbox to model and persist Services in this scan. |
| Service ID | N/A | No | Model & Persist only the Services with the IDs given in this input field. |
| Vendor Name | N/A | No | The Vendor Name |
Conditions and Processors of Abstract SDH Service Actions
The Abstract SDH Service Actions contains the following processors run in the following order:
- Service Import Initializer Processor
- Service Modeler Processor
The Service Import Initializer processor provides variable serviceIds of type Set and serviceUIMImportContextList of type List. This is performed only if the Service option is selected in the SDH Import Parameters or SDH Incremental Import Parameters scan parameter group.
The Service Modeler Processor uses serviceIds and serviceUIMImportContextList as input parameters. The services with IDs in serviceIds set are imported with parallel processing. This is performed only if the Service option is selected in the SDH Import Parameters or SDH Incremental Import Parameters scan parameter group.
Import SDH Connectivity and Service From UIM
The Import SDH Connectivity and Service From UIM action extends the Abstract Optical Import From UIM to fetch the logical device details which are used to fetch the associated connectivities and service from UIM.
The Import SDH Connectivity and Service From UIM action extends the Abstract SDH Service Actions. This action fetches the logical device details from the inputs which are used to fetch the associated connectivities and service from UIM. It contains the following scan parameter groups:
Table 2-2 SDH Import Parameters
The Import SDH Connectivity and Service From UIM action contains the following conditions:
- IsServiceImportSelected Condition
The Import SDH Connectivity and Service From UIM action contains the following processors run in the following order:
- SDH Import UIM Initializer Processor
- Optical Logical Device Finder Processor
- SDH Multithread TL Importer Processor
- SDH Multithread Trail Importer Processor
- SDH Multithread Tunnel Importer Processor
- Service Import Initializer Processor (inherited)
- Service Finder Processor
- Service Modeler Processor (inherited)
This condition checks if the Service import is selected in the scan parameters.
The SDH Import UIM Initializer Processor outputs the variable filters of type DeviceFilter with default values already populated and the variable uimImportContext of type UIMImportContext, which contains a context used by multiple processors.
The Optical Logical Device Finder Processor uses filters and uimImportContext as input parameters to perform one or more Logical Device find operations through the UIM web service API. This processor provides the output through the variable logicalDeviceIdNameMap of type Map with the device ID as key and the device name as value, the variable uimImportContext of type UIMImportContext containing context used by multiple processors and also the variable uimLogicalDeviceIDs of type Set.
The SDH Multithread TL Importer processor uses the logicalDeviceIdNameMap, uimLogicalDeviceIDs, and uimImportContext as input parameters; This processor imports the Topological Links associated with the input logical devices using parallel processing.
The SDH Multithread Trail Importer processor uses the logicalDeviceIdNameMap, uimLogicalDeviceIDs, and uimImportContext as input parameters; This processor imports the Trails associated with the input logical devices using parallel processing.
The SDH Multithread Tunnel Importer processor uses the logicalDeviceIdNameMap, uimLogicalDeviceIDs, and uimImportContext as input parameters; This processor imports the Tunnels associated with the input logical devices using parallel processing.
The Service Finder processor uses the serviceIds, serviceUIMImportContextList and uimImportContext as input parameters. This processor creates the request to find Services based on the input service IDs.
Incremental Import SDH Connectivity and Service From UIM
The Incremental Import SDH Connectivity and Service From UIM action extends the Abstract Optical Import From UIM and performs Incremental Import for connectivities and service from UIM.
The Incremental Import SDH Connectivity and Service From UIM action contains the following scan parameter groups:
- SDH Incremental Import Parameters
Table 2-3 SDH Incremental Import Parameters
| Vendor Name | N/A | No | The Vendor Name. |
| NMS Notification Count | N/A | No | The maximum number of NMS notifications to be processed. |
| Topological Link | N/A | No | Select this checkbox to import and model Topological Links in this scan. |
| Trail | N/A | No | Select this checkbox to import and model Trails in this scan. |
| Tunnel | N/A | No | Select this checkbox to import and model Tunnel in this scan. |
| Service | N/A | No | Select this checkbox to import and model Services in this scan. |
The Incremental Import SDH Connectivity and Service From UIM action contains the following conditions:
- IsTLImportEnabled Condition
- IsTrailImportEnabled Condition
- IsTunnelImportEnabled Condition
- IsServiceImportEnabled Condition
The Incremental Import SDH Connectivity and Service From UIM action contains the following processors run in the following order:
- Incremental Import Initializer Processor
- Incremental TL Names Collector Processor
- Incremental Trail Names Collector Processor
- Incremental Tunnel Names Collector Processor
- Incremental Service Names Collector Processor
- Topological Link Multi Thread Incremental Importer Processor
- Trail Multi Thread Incremental Importer Processor
- Tunnel Multi Thread Incremental Importer Processor
- Incremental Service Finder Processor
- Update SDH Notifications to Import Status Processor
The condition checks if the Topological Link import is selected in the scan parameters.
The condition checks if the Trail import is selected in the scan parameters.
The condition checks if the Tunnel import is selected in the scan parameters.
The condition checks if the Service import is selected in the scan parameters.
The Incremental Import Initializer processor creates the required data structures for incremental import: tlNames, trailIds, tunnelIds, and serviceNames.
The Incremental TL Names Collector processor displays the set tlNames . The NMS Notification manager fetches the required TL names from the database.
The Incremental Trail Names Collector processor displays the set trailIds . The NMS Notification manager fetches the required Trail IDs from the database.
The Incremental Tunnel Names Collector processor displays the set tunnelIds . The NMS Notification manager fetches the required Tunnel IDs from the database.
The Incremental Service Names Collector processor displays the set serviceNames . The NMS Notification manager fetches the required Service names from the database.
The Topological Link Multi Thread Incremental Importer processor uses the tlNames and uimImportContext as input parameters; This processor performs Incremental import over the TL names using parallel processing.
The Trail Multi Thread Incremental Importer processor uses the trailIds and uimImportContext as input parameters. This processor performs Incremental import over the Trail Ids using parallel processing.
The Tunnel Multi Thread Incremental Importer processor uses the tunnelIds and uimImportContext as input parameters. This processor performs Incremental import over the Tunnel Ids using parallel processing.
The Incremental Service Finder processor uses the serviceIds, serviceNames, serviceUIMImportContextList and uimImportContext as input parameters. This processor creates the request to find services based on the input service IDs during Incremental Import.
The Update SDH Notifications to Import Status processor updates the NMS notification status to IMPORTED for entries in tlNames, trailIds, tunnelIds, and serviceNames.
The Detect Discrepancies for SDH Connectivity and Service action detects discrepancies between discovery scan results of Discover SDH Connectivity and Service action and data imported from UIM.
This discrepancy detection action extends the Discrepancy Detection action from the NetworkIntegritySDK cartridge and inherits all its processors.
The Detect Discrepancies for SDH Connectivity and Service action contains the following processors run in the following order:
DD Filters Initializer
Discrepancy Detector (inherited)
Detect Discrepancy Filters Initializer Processor
This processor implements the following filters:
- Ignore ID on all entities.
- Use Name as the comparator across all entities to determine whether objects from discovery and import are the same.
- Ignore case sensitivity for entity relationship for port termination point.
- On a Pipe, ignore the ID, physical location, description, rerouted, partial, sequence, AEnd, ZEnd, and nativeEMSName.
- On Service and Service Configuration, ignore the ipAddress.
- Ignore partial circuits, containers, and channels
Resolve SDH Connectivity and Service in UIM
The Resolve SDH Connectivity and Service in UIM action resolves discrepancies between discovery scan results of Discover SDH Connectivity and Service action and data imported from UIM.
This discrepancy resolution action extends the Abstract Resolve in UIM action from the UIM Integration cartridge and inherits all its processors. For information about the inherited processors, see Network Integrity UIM Integration Cartridge Guide.
The Resolve SDHConnectivity and service in UIM action contains the following processors run in the following order:
- UIM Resolution Framework Initializer (inherited)
- UIM Resolution Initializer (inherited)
- Optical Resolution Initializer
- UIM Resolution Framework Dispatcher (inherited)
Optical Resolution Initializer Processor
This processor registers the following handlers required for connectivities and service resolution:
- PipeTerminationPointHandler
- CircuitHandler
- TrailPathHandler
- ServiceHandler
- ServiceConfigurationItemHandler
Supported Creation Scenarios in UIM
This section describes the following creation scenarios, which are supported in UIM:
- Creation of a Topological Link (Channelized Connectivity & INNI Connectivity specifications)
- Creation of a Trail
- Creation of a Tunnel
- Creation of a TrailPipe
- Creation of a PipeTerminationPoint
- Creation of a TrailPath
- Creation of a Service
- Creation of a ServiceConfigurationItem
- Topological Link
- Trail
- Tunnel
- Service
When a Topological Link is discovered and when it does not exist in UIM, Network Integrity displays Entity+ for the Topological Link.
The resolution creates the Topological Link. The Topological Link is associated with the device.
Creation of a Trail
When a Trail is discovered and when it does not exist in UIM, Network Integrity displays Entity+ for the Trail.
The resolution creates the Trail. The Trail is associated with the device.
When a Tunnel is discovered and when it does not exist in UIM, Network Integrity displays Entity+ for the Tunnel.
The resolution creates the Tunnel. The Tunnel is associated with the device.
When a Trail or Tunnel is discovered and when it does not exist in UIM, Network Integrity displays Entity+.
The resolution creates the TrailPipe segment. The TrailPipe segment is associated with the Trail or Tunnel.
When a Topological Link, Trail ,or Tunnel is discovered and when it does not exist in UIM, Network Integrity displays Entity+.
The resolution creates the PipeTerminationPoint which also creates a DeviceInterface. ThePipeTerminationPoint is associated with the Topological Link, Trail or Tunnel and the DeviceInterface is associated with the Device.
The resolution creates the TrailPath. The TrailPath is associated with the Trail or Tunnel.
When a Service is discovered and when it does not exist in UIM, Network Integrity displays Entity+ for the Service.
The resolution creates the Service and its child objects. As each object is created, it is associated to the Service.
When a ServiceConfigurationItem is discovered and when it does not exist in UIM, Network Integrity displays Entity+.
The resolution creates ServiceConfigurationItem and its child objects. ServiceConfigurationItem is associated to the service.
If multiple resolution requests sharing a common logical device are sent to UIM at the same time, it is possible that UIM may fail some of the requests with the OptimisiticLockException error. This can be resolved by adding the uim.inverserel.update.disable=true property inside the system-config.properties file in UIM. For more information about this file, see "Setting System Properties" in UIM System Administrator's Guide.
Teardown, Deletion, and Removal Scenarios in UIM
This section describes the following teardown, deletion, and removal scenarios, which are supported in UIM:
- Deletion of a Topological Link
- Deletion of a Trail
- Deletion of a Tunnel
- Removal of a Connectivity Design Path from Connectivity
- Deletion of a PipeSegment
- Deletion of a TrailPath
- Deletion of a Service
- Deletion of a ServiceConfigurationItem
- Removal of a ServiceConfigurationItem from Service
The order of reconciliation for the Delete operations from NI must be as follows:
- Service
- Tunnel
- Trail
- Topological Link
When a Topological Link exists in UIM but is not discovered, Network Integrity displays Entity-.
If the Topological Link has only one design version and is in INPROGRESS state, the Topological Link is deleted upon resolution.
Deletion of a Trail
When a Trail exists in UIM but is not discovered, Network Integrity displays Entity-.
If the Trail has only one design version and is in INPROGRESS state, the Trail is deleted upon resolution.
When a Tunnel exists in UIM but is not discovered, Network Integrity displays Entity-.
If the Tunnel has only one design version and is in INPROGRESS state, the Tunnel is deleted upon resolution.
When a Topological Link, Trail, or Tunnel exists in UIM but is not discovered, Network Integrity displays Entity-.
The resolution of Entity- removes the connectivity design path from the connectivity.
The resolution of Entity- deletes the PipeSegment from the connectivity.
When a Trail or Tunnel exists in UIM but is not discovered, Network Integrity displays Entity-.
The resolution of Entity- deletes the TrailPath from the Trail or Tunnel.
When a Service exists in UIM but is not discovered, Network Integrity displays Entity-.
The resolution of Entity- deletes the Service.
When a ServiceConfigurationItem exists in UIM but is not discovered, Network Integrity displays Entity-.
The resolution of Entity- deletes the ServiceConfigurationItem.
The resolution of Entity- removes the ServiceConfigurationItem from the Service.
Mismatched Data Scenarios
This section describes the mismatched data scenarios:
- Mismatch of Topological Link data
- Mismatch of Trail data
- Mismatch of Tunnel data
- Mismatch of channel data in a TrailPipe
- Mismatch of Service data
- Mismatch of ServiceConfigurationItem data
When the Topological Link data in UIM has data that does not match the discovered data, Network Integrity displays Mismatch.
The resolution updates the mismatched Topological Link data attribute in UIM and sets the value in UIM to the discovered value.
When the Trail data in UIM has data that does not match the discovered data, Network Integrity displays Mismatch.
The resolution updates the mismatched Trail data attribute in UIM and sets the value in UIM to the discovered value.
When the Tunnel data in UIM has data that does not match the discovered data, Network Integrity displays Mismatch.
The resolution updates the mismatched Tunnel data attribute in UIM and sets the value in UIM to the discovered value.
When the channel data in a TrailPipe in UIM is different from the one in Network Integrity, Network Integrity displays Mismatch.
The resolution updates the channel data in UIM and sets the value in UIM to the discovered value.
When the Service data in UIM has data that does not match the discovered data, Network Integrity displays Mismatch.
The resolution updates the mismatched Service data attribute in UIM and sets the value in UIM to the discovered value.
When the ServiceConfigurationItem data in UIM has data that does not match the discovered data, Network Integrity displays Mismatch.
The resolution updates the mismatched ServiceConfigurationItem data attribute in UIM and sets the value in UIM to the discovered value.
Groom Support for SDH
Grooming a connectivity is changing the design path of a connectivity by either changing segment's channel within a facility or to a channel from different facility. For example, when you groom a SDH Trail connectivity, you change the VC12 channel within same STM16 facility or to a VC12 channel from different STM4/STM16 facility.
The groom feature can also be used for:
- Reallocating bandwidth to ensure optimal usage
- Consolidating traffic to make better use of high-capacity links
- Upgrading equipment with newer, more capable devices
Grooming frequently happens due to network modifications that introduce new routes or render existing ones less effective. For example, the addition of new devices to a network might cause existing routes to have unacceptable number of hops. Planning and management procedures identify such scenarios and recommend more efficient routing adjustments through grooming. For more information, see UIM Concepts.
UIM exposes a Groom API via the REST protocol. Network Integrity identifies design path discrepancies for each connectivity rider, triggering a groom request and calling UIM's Groom endpoint. Upon receiving the groom request, UIM promptly acknowledges it with a 202 response and processes it in the background. Network Integrity then regularly checks UIM for a Groom response and addresses the discrepancies accordingly.
For more information on how to invoke Groom REST APIs, see REST API for Unified Inventory Management.
A default API is introduced within the DiscrepancyHandler interface of the UIM_Integration_Cartridge, which takes collections of discrepancies (such as attribute mismatches, missing or extra pipe segments) and the reference pipe entity (either trails or tunnels) as inputs, as shown below. Reconciliation handler classes can be used to override this API.
For SDH or Ethernet networks, groom can be used on trail or tunnel connectivities by modifying the necessary segments, or changing channels within existing segments.
public default void handleDiscrepancyGroom(Collection<DisDiscrepancy> missingEntity, Collection<DisDiscrepancy> extrEntity, Collection<DisDiscrepancy> attributeMismatch, Pipe pipe) {
}The input to the API is passed from the oracle.communications.integrity.uim.resolutionprocessors.base.BaseResolutionElement class within the UIM_Integration_Cartridge. This class has the logic to group discrepancies respective to the attribute mismatches, missing or extra entities, and reference root entities for each result group.
The oracle.communications.integrity.sdhuim.resolutionprocessors.opticalresolutioninitializer.CircuitHandler OOB reconciliation handler has the logic to Groom SDH connectivities.
Rehome Support for SDH
When you rehome a connectivity, you alter one of its endpoints. This action may be necessary for load balancing purposes or due to the removal or replacement of devices and interfaces. For more information, see UIM Concepts.
- Moving customer connections to different network nodes to improve service quality
- Physically relocating network devices to different location
- Switching network services from one provider to another
- Shifting network resources, such as IP addresses or bandwidth, to different parts of the network.
Rehoming a facility requires changes to the termination of the facility itself and to any channels it provides. Channels are re-terminated on sub-device interfaces provided by the new device interface on which the facility is terminated.
UIM exposes a Rehome API over REST protocol. Network Integrity detects such port change discrepancies for each connectivity facility and generates a Rehome request and invokes Rehome endpoint of UIM. Upon receiving the rehome request, UIM immediately acknowledges with a 202 response and processes it in the background. Network Integrity then regularly checks UIM for a Rehome response and addresses the discrepancies accordingly.
For more information on how to invoke Rehome REST APIs, see REST API for Unified Inventory Management.
A default API is introduced within the DiscrepancyHandler interface of the UIM_Integration_Cartridge, which takes a collection of discrepancies (such as missing or extra pipe or PTP entities) as input, as shown below. You can use reconciliation handler classes to override this API.
For SDH or Ethernet networks, rehome can be used on topological link, trail or tunnel pipes by modifying device changes or termination point changes on one side.
public default void handleDiscrepancyRehome(DisDiscrepancy missingEntity, DisDiscrepancy extrEntity){
The following OOB reconciliation handlers have the logic to rehome SDH connectivities:
oracle.communications.integrity.sdhuim.resolutionprocessors.opticalresolutioninitializer.CircuitHandler – When a pipe entity’s identifier changes due to change on one side of the device or termination point, a discrepancy is generated on the pipe entity. This handle is invoked for such discrepancies.
oracle.communications.integrity.sdhuim.resolutionprocessors.opticalresolutioninitializer.PipeTerminationPointHandler – When a pipe entity's identifier stays unique even when one side of the device or termination point changes, then discrepancies are recorded at the Pipe's termination point. This handler is invoked for such discrepancies.
Using the Cartridge
This section provides instructions for using the Oracle Communications Network Integrity SDH UIM Integration cartridge in Network Integrity.
Creating an Import SDH Connectivity and Service From UIM Scan
The Import SDH Connectivity and Service From UIM scan is used to import and model connectivities such as Topological Links, Trails, Tunnels, and Services.
To create an Import SDH Connectivity and Service From UIM scan:
- Create a new scan.
See Network Integrity Online Help for more information.
- On the General tab, do the following:
- From the Scan Action list, select Import SDH Connectivity and
Service From UIM.
The Scan Type field displays Import
- In the Scan Action Parameters section, SDH Import Parameters is selected by default.
- (Optional) Enter the required parameters of the logical device and service parameters.
Service From UIM.
- Save and run the scan.
Figure 2-1 Creation of an Import SDH Connectivity and Service from UIM scan
Creating an Incremental Import SDH Connectivity and Service From UIM Scan
The Incremental Import SDH Connectivity and Service From UIM scan is used to import and model connectivities such as Topological Links, Trails, Tunnels, and Services using NMS notifications.
To create an Incremental Import SDH Connectivity and Service From UIM scan:
- From the Scan Action list, select Incremental Import SDH
Connectivity and Service From UIM.
- In the Scan Action Parameters section, SDH Incremental Import Parameters is selected by default.
- Enter the required parameters.
Figure 2-2 Creation of an Incremental Import SDH Connectivity and Service from UIM scan
Populating UIM with Discovered SDH Connectivities and Services
This procedure describes how to process UIM with network data discovered by the Discover SDH Connectivity and Service discovery action.
To process UIM with discovered network data:
- From the Scan Action list, select Discover SDH Connectivity and
Service.
The Scan Type field displays Discovery.
- Select Detect Discrepancies.
- In the Scan Action Parameters section, SDH File Parameters is selected by default.
- Enter the FTP related parameters.
- From the Scan Action Parameters list, select SDH Device Parameters.
- Select the type of entities to model and the required filters such as Name, ID, Device Name, and so on.
- Enter the Circle Name and Vendor name.
- If Incremental Discovery is to be performed, select Incremental Discovery from the Scan Action Parameters list. Select Incremental Discovery option and the type of entities to be modeled.
Service.
- On the Scope tab, specify path to the file directory.
- Using UIM, create the required Logical Devices with Optical Logical Device specification from ora_ni_uim_sdh_optical.
Service From UIM.
- Enter the required parameters of the logical device created above.
Service From UIM.
The logical devices should be present as part of the scan result.
- Run the discovery scan again.
- The scan generates Entity+ discrepancies for each discovered device.
- Right-click on the discrepancies you want to populate in UIM and select Correct SDH Connectivity and Service in UIM.
- Click Submit.
- Verify that UIM displays the discovered data.
Synchronizing UIM and NI with NMS Notifications of SDH Connectivities
This procedure describes steps to synchronize UIM with network data using NMS Notifications and incremental scans.
To populate UIM with discovered network data:
Populate the NMSNotification table in the database with the record of SDH Connectivities and set the status is set to INITIAL.
Create a new scan.
From the Scan Action list, select Incremental Import SDH Connectivity and Service From UIM.
The Scan Type field displays Import.
- In the Scan Action Parameters section, SDH Incremental Import Parameters option is selected by default. Enter the required parameters
The connectivities present in UIM will be imported to NI and the status of the records will be changed to IMPORTED.
From the Scan Action list, select Discover SDH Connectivity and Service.
- In the Scan Action Parameters section, SDH File Parameters option is selected by default. Enter the FTP related parameters.
- Click on the Scan Action Parameters drop down and select SDH Device Parameters. Enter the Circle Name and Vendor name.
- From the Scan Action Parameters drop down, select Incremental Discovery.
- Select the Incremental Discovery option and the type of entities to be modeled.
The SDH connectivities present in the database are discovered as per the input files and the status of the records will be changed to DISCOVERY_SUCCESSFUL. The scan generates discrepancies as per the two previous scans.
Click Submit.
Verify that UIM is populated with the required data.
About Cartridge Modeling
The Oracle Communications Network Integrity SDH UIM Integration cartridge models collected data according to the Oracle Communications Information Model.
For information about the following, see SDH Discovery Cartridge:
- Pipe Specifications
- Pipe Termination Point Specifications
- Service Specifications
- Service Configuration Specifications
Shared Specifications
You must first model inventory (UIM) specifications in an inventory cartridge using Design Studio, define the cartridge dependency such that the Network Integrity cartridge is dependent on the inventory cartridge, and then use the inventory cartridge specifications in the Network Integrity cartridge model.
Specifications shared with Oracle Communications Unified Inventory Management (UIM) are defined in the SDH_Service_Model and ora_ni_uim_sdh_optical cartridges. These cartridges are used to directly deploy specifications to UIM.
The following table shows the list of specifications.
Table 2-4 List of Specifications
| Specification | Entity | Cartridge |
| TRAIL | Connectivity Function | ora_ni_uim_sdh_optical |
| TUNNEL | Connectivity Function | ora_ni_uim_sdh_optical |
| Channelized Connectivity | Connectivity | ora_ni_uim_sdh_optical |
| ENNI Connectivity | Connectivity | ora_ni_uim_sdh_optical |
| INNI Connectivity | Connectivity | ora_ni_uim_sdh_optical |
| Service Connectivity | Connectivity | ora_ni_uim_sdh_optical |
| TDM Connectivity | Connectivity | ora_ni_uim_sdh_optical |
| Trail | Connectivity | ora_ni_uim_sdh_optical |
| Tunnel | Connectivity | ora_ni_uim_sdh_optical |
| 40GigE | Device Interface | ora_ni_uim_sdh_optical |
| VC12_1 to VC12_63 | Device Interface | ora_ni_uim_sdh_optical |
| VC3_1 to VC3_40 | Device Interface | ora_ni_uim_sdh_optical |
| VC4_1 to VC4_64 | Device Interface | ora_ni_uim_sdh_optical |
| Ethernet Terminates Packet Rider Configuration | Flow Interface Configuration | ora_ni_uim_sdh_optical |
| Ethernet Terminates Packet Rider | Flow Interface | ora_ni_uim_sdh_optical |
| Optical Logical Device | Logical Device | ora_ni_uim_sdh_optical |
| SDH_Service | Service | SDH_Service_Model |
| SDH_Service_Configuration | Service Configuration | SDH_Service_Model |
About Design Studio Construction
This section provides information on the composition of the Oracle Communications Network Integrity SDH UIM cartridge from the Oracle Communications Design Studio perspective.
Model Collections
The following table shows the SDH UIM Cartridge model collection.
Table 2-5 SDH UIM Cartridge Model Collection
| Specification | Information Model Entity Type | Intended Usage/Notes |
| Topological Link | Pipe | Represents Topological Link connectivity |
| Optical Trail Pipe | Pipe | Represents Optical Trail Pipe which form the segments of an optical path |
| VC12Circuit | Pipe | Represents VC12 type of trail connectivity |
| VC3Circuit | Pipe | Represents VC3 type of trail connectivity |
| VC4Circuit | Pipe | Represents VC4 type of trail connectivity |
| EthTunnel | Pipe | Represents EthTunnel type of tunnel connectivity |
| Port Termination Point | Pipe Termination Point | Represents Port Termination Point which acts as a device end |
| SDH_Service | Service | Represents SDH_Service that manages the network |
| SDH_Service_Configuration | Service Configuration | Represents SDH_Service_Configuration |
Import Actions
SDH UIM Cartridge supports the following import actions.
Table 2-6 Abstract SDH Service Actions
| Result Category | Address Handler | Scan Parameters | Model | Processors |
N/A |
SDH_UIM_Cartridge |
Table 2-7 Import SDH Connectivity and Service From UIM
N/A |
SDH_UIM_Cartridge |
Table 2-8 Incremental Import SDH Connectivity and Service From UIM
N/A |
SDH_UIM_Cartridge |
Import Processors
Table 2-9 Abstract SDH Service Actions Action Processors
| Processor Name | Variable |
| Service Import Initializer |
Input: N/A Output:
| Service Modeler |
Input:
Output: N/A |
Table 2-10 Import SDH Connectivity and Service From UIM Action Processors
| SDH Import UIM Initializer |
Input: N/A Output:
| Optical Logical Device Finder |
Input:
Output:
| SDH Multithread TL Importer |
Input:
Output: N/A |
| SDH Multithread Trail Importer |
Input:
Output: N/A |
| SDH Multithread Tunnel Importer |
Input:
Output: N/A |
| Service Finder |
Input:
Output: N/A |
Table 2-11 Incremental Import SDH Connectivity and Service From UIM Action Processors
| Incremental Import Initializer |
Input: N/A Output:
| Incremental TL Names Collector |
Input:
Output: N/A |
| Incremental Trail Names Collector |
Input:
Output: N/A |
| Incremental Tunnel Names Collector |
Input:
Output: N/A |
| Incremental Service Names Collector |
Input:
Output: N/A |
| Topological Link Multi Thread Importer |
Input:
Output: N/A |
| Trail Multi Thread Importer |
Input:
Output: N/A |
| Tunnel Multi Thread Importer |
Input:
Output: N/A |
| Incremental Service Finder |
Input:
Output: N/A |
| Update SDH Notifications to Import Status |
Input:
Collections of IDs and names over which incremental import is performed. Output: N/A |
Discrepancy Detection Action
Detect Discrepancies for SDH Connectivity and Service is the action you use to perform Discrepancy detection.
Table 2-12 Detect Discrepancies for SDH Connectivity and Service
| Result Category | Result Source | Scan Parameters | Model | Processors |
| All |
N/A | SDH_UIM_Cartridge |
Table 2-13 Detect Discrepancies for SDH Connectivity and Service Action Processors
| DD Filters Initializer |
Input: N/A Output: N/A |
Discrepancy Resolution Action
Resolve SDH Connectivity and Service in UIM is the action you use to perform Discrepancy Resolution.
Table 2-14 Resolve SDH Connectivity and Service in UIM
| Result Category | Result Source | Processors |
| All |
Table 2-15 Resolve SDH Connectivity and Service in UIM Action Processors
| Optical Resolution Initializer |
Input:
Output: N/A |
