5 About Optical FTP Discovery Input File Structure
For Optical Devices FTP scan to work, the files must be populated with the corresponding value.
Table 5-1 List of Supported Files
File Name Mandatory Description
NE_REPORT_FILE
YES This file contains NetworkElement information.
SUBRACK_REPORT_FILE_NAME
YES This file contains Sub_Rack (Equipment Chassis) information.
BOARD_REPORT_FILE
YES This file contains Card related information present under Sub_Rack.
PORT_REPORT_FILE
YES This file contains port Information.
PHYSICAL_LOCATION_FILE
YES This file contains Physical Location details of NetworkElement.
Interface_Resource_Report_File YES This file contains Device Interface details and Mapping between PhysicalPort Information.
File naming convention can be changed by making the necessary changes inside opticalfiles.properties located at Optical_FTP_Discovery_Cartridge/src. Each file is structured with a predetermined set of columns, each containing essential device information.
In each file, the initial seven lines are reserved for report-related information and are not utilized. The eighth line serves as the actual header, defining the columns. The subsequent lines contain the specific details pertaining to each device
NE Report File
The following table shows the list of column headers required within the file.
Table 5-2 NE Report File
Header Name Essential (Data) Description
NE Name YES Network Element name
NE Type YES Type of Device Model
NE ID YES Unique Id that represent Network Element
Subrack Type YES Subrack Type
Software Version NO Software Version been used by the device
Sub_Rack Report File
Table 5-3 Sub_Rack Report File
NE YES Network Element under which this rack is present
Subrack Name YES Rack name
Subrack Type YES Type of Rack
Subrack ID YES Unique Id to represent Rack
Software Version NO Rack Software
SN(Bar Code) NO Bar Code Information
Description NO Rack Description
Subnet NO Subnet Related information
Subnet Path NO Subnet Path Information
Board Report File
Table 5-4 Board Report File
NE YES Network Element under which this board is present
NE Type YES Network Element Type
Board Name YES Board Name
Board Type YES Board Type
Subrack ID YES Rack (Id)under which this board is present
Slot ID YES Container (Id) that hold this board
Hardware Version NO Board Hardware Version
SN(Bar Code) NO Board SN(Bar Code)
Serial Number NO Board Serial Number
Software Version NO Board Software Version
Description NO Board Description
Physical_Location File
Table 5-5 Physical_Location File
Location YES Physical Location
Physical Location Report Sample File
Interface_Resource_Report File
Table 5-6 Interface_Resource_Report File
Interface Name YES Interface Name
Interface Description NO Interface Description
Ipv4Address NO IPV4 Address
Ipv6Address NO IPV6 Address
Interface Type NO Interface Type
Speed NO Interface Supported Speed
Status NO
Interface Status
Supported Value.(UP /DOWN)
MtuCurrent NO Interface MtuCurrent Details
Port Mapping NO
Interface-PhysicalPort Mapping details
Supported Value Format:
  • ShelfNo:SlotNo:PortNo:PortName
  • SlotNo:PortNo:PortName
  • null
