- High Availability Guide
- High Availability Configuration for Virtual Appliances
- Configuring High Availability on KVM
- Create Linux/Networking Bridge
Follow
these instructions to create a networking bridge.
- Log in to the KVM server.
- Create a file
called
ifcfg-lanbrN
and replace N with the interface number under/etc/sysconfig/network-scripts/
. - Open the file in an
editor and enter the following
[localadmin@localhost network-scripts]$ cat ifcfg-lanbr201 DEVICE=lanbr201 TYPE=Bridge BOOTPROTO=none ONBOOT=yes DELAY=0 [localadmin@localhost network-scripts]$
- To add the virtual
interface to the LAN bridge, ensure
ONBOOT=yes
andBRIDGE=
the name of the LAN bridge in theifcfg-ens2f0
file, whereifcfg-ens2f0
is the virtual interface.[localadmin@localhost network-scripts]$ cat ifcfg-ens2f0 TYPE=Ethernet PROXY_METHOD=none BROWSER_ONLY=no BOOTPROTO=dhcp DEFROUTE=yes IPV4_FAILURE_FATAL=no IPV6INIT=yes IPV6_AUTOCONF=yes IPV6_DEFROUTE=yes IPV6_FAILURE_FATAL=no IPV6_ADDR_GEN_MODE=stable-privacy NAME=ens2f0 UUID=bf4196e3-b003-41ff-8b02-29ed79ea3552 DEVICE=ens2f0 ONBOOT=yes BRIDGE=lanbr201 [localadmin@localhost network-scripts]$
- Create a WAN bridge by logging into the KVM server.
- Create a file
called
ifcfg-wanbrN
editor and enter the following.
[localadmin@localhost network-scripts]$ cat ifcfg-wanbr201 DEVICE=wanbr201 TYPE=Bridge BOOTPROTO=none ONBOOT=yes DELAY=0 [localadmin@localhost network-scripts]$
interface to the WAN bridge, ensure
ONBOOT=yes
andBRIDGE=
the name of the WAN bridge in theifcfg-ens2f1
file, whereifcfg-ens2f1
is the virtual interface.[localadmin@localhost network-scripts]$ cat ifcfg-ens2f1 TYPE=Ethernet PROXY_METHOD=none BROWSER_ONLY=no BOOTPROTO=dhcp DEFROUTE=yes IPV4_FAILURE_FATAL=no IPV6INIT=yes IPV6_AUTOCONF=yes IPV6_DEFROUTE=yes IPV6_FAILURE_FATAL=no IPV6_ADDR_GEN_MODE=stable-privacy NAME=ens2f1 UUID=f45577ab-f733-4c53-a791-fe44662cc5b4 DEVICE=ens2f1 ONBOOT=yes BRIDGE=wanbr201 [localadmin@localhost network-scripts]$
- Restart the network
by entering the following.
$sudo systemctl restart network
- Verify the
interfaces are connected to the bridges by entering the following.
The interfaces should look like the following$sudo brctl show
[localadmin@localhost network-scripts]$ brctl show bridge name bridge id STP enabled interfaces lanbr201 8000.3cfdfe6272a8 no ens2f0 vnet0 lanbr202 8000.3cfdfe6272aa no ens2f2 vnet1 lanbr203 8000.3cfdfe6272b8 no ens3f0 vnet2 wanbr201 8000.3cfdfe6272a9 no ens2f1 vnet3 wanbr202 8000.3cfdfe6272ab no ens2f3 vnet4 wanbr203 8000.3cfdfe6272b9 no ens3f1 vnet5 vnet6 [localadmin@localhost network-scripts]$
