Activation Project Editor Testing Tab
Use the Testing tab to view ASAP test cases that you created for your projects and run them individually or simultaneously.
| Field | Use |
                               Environment  |
                               Select a run-time environment that has configuration for an ASAP environment.  |
                               Include all from Project  |
                               Select to include all test case entities.  |
                               Entity  |
                               Displays activation test case entities.  |
                               Status  |
                               Displays the status of a work order.  |
                               Run All  |
                               Click to run all test cases one by one in the run-time environment.  |
                               Separate Console for each Test Case  |
                               Select to open a different console window for each test case in a run-time environment.  |
                               Select  |
                               Click to add a test case entity from the project.  |
                               Open  |
                               Click to open a specific test case entity.  |
                               Remove  |
                               Click to clear a specific test case entity from the Testing tab.  |
                               Run  |
                               Click to run a specific test case.  |
