8 Testing ASAP Cartridges in Design Studio
An Activation test case (a test work order) enables you to test, in Design Studio, the activation order completion for a cartridge project to verify that a work order is sent to the Oracle Communications ASAP environment. Consider the following when creating and running test cases:
Each test case can have multiple service actions.
It is possible to run multiple tests that are almost identical except for different parameters. Design Studio runs all of the cases in sequence.
Test cases use OSSJ interface.
To test ASAP cartridges in Design Studio, you create an activation test case, then you run the test case.
Do not submit an activation test case over an SSL connection.
See the following topics:
