Associating Service Actions with the Service Bundle
To associate service actions with the service bundle:
In the Studio Projects view, double-click a Service Bundle entity.
The Service Bundle editor opens.
On the Service Actions tab, click Add.
The Service Action Selection dialog box.
Using the Service Action Selection dialog box, you can either select or create a service action entity.
In the Service Action Selection dialog box, select an existing service action entity or create a new service action entity.
When prompted to create upstream interface parameters based on service action labels, select Yes to automatically create upstream interface parameters based on the service action labels of the service actions that you have selected.
The parameters appear in the Upstream Interface tab. A mapping between each upstream parameter and each service action parameter is created automatically.
(Optional) Select a service action and click the arrow keys to reorder the service actions.
Additionally, you can manually enter interface parameters or import them from a sample upstream XML document. See "Mapping Upstream Interface Parameters to Service Action Parameters" and "Importing Upstream Parameters" for more information.
Click the SA Parameter Map tab.
This tab displays the service action parameters. You can map the service actions to service bundles.
This feature is useful if you do not have sufficient information on the upstream parameters (such as the exact parameter labels that are provided on the incoming XML). This feature assumes that the parameter labels required by the service action are the same as those on the upstream order. The selected service actions appear in the Service Bundle Details area of the Service Bundle editor with their associated attributes (sequence, service action name, condition, label, value, expression, vendor, technology, software load and action).
Click Save.
Related Topics
