Defining Upstream Interface Parameters Manually
To define upstream interface parameters manually:
On the Service Bundle editor, click the Upstream Interface tab, and then click Add in the Service Bundle Details area.
In the Upstream Interface Details tab, enter the following information:
In the Name field, enter the name of the upstream parameter.
In the Default field, enter the default value of the upstream parameter. If the upstream parameter does not have a value, the default is supplied to ASAP.
In the Data Type field, enter the parameter's data type.
Select Multi Instance if the specified label is the stem of a series of parameters. This allows for a dynamic number of instances and possible use with ASAP's indexing capability for spawning multiple atomic actions.
Enable Required if this upstream parameter is required.
Related Topics
Working with Upstream Interface Parameters
Mapping Upstream Interface Parameters to Service Action Parameters
