Modeling Order Component Control Data Automatically
You must define configuration settings and set up orchestration entities correctly to ensure that Design Studio can model the order component control data automatically by using the OracleComms_OSM_CommonDataDictionary model project.
If you are not using the OracleComms_OSM_CommonDataDictionary model project, do not follow these instructions. See "Modeling Order Component Control Data Manually" and model the order component control data structure manually.
To model order component control data automatically (or rather, ensure Design Studio can model it automatically):
Verify that the OracleComms_OSM_CommonDataDictionary model project is in your workspace.
If you do not have the model project in your workspace, see the discussion on defining orchestration preferences (for the Common Data Dictionary field) in "Defining OSM Preferences".
Verify that orchestration entities are set up for the orchestration plan in which the order component is to be included.
See "About Autogeneration of Order Component Control Data" for more information.
Create the order component specification for the orchestration order.
Add the order component to the orchestration fulfillment pattern.
Design Studio creates the order component control data structure automatically by using the data schema elements of the OracleComms_OSM_CommonDataDictionary project as base elements for the structure.
Verify that Design Studio has added the order component control data structure to the following areas:
Order Template tab of the order component
If you do not see the order component control data structure in the preceding areas after adding the order component to the orchestration fulfillment pattern, your OSM orchestration entities may not be set up correctly. See "About Autogeneration of Order Component Control Data" for information on the orchestration entities that must be in place for auto generation of order component control data.
Save all orchestration entities.
