About the Process Editor
The Process editor is a canvas where you can configure new services quickly and with minimal data; designing with the Process editor is analogous to capturing your workflow requirements on a white board. Designers using the Process editor to model new services do not need to understand the OSM technology behind the processes and integrations. As a designer begins sketching out the initial processes and tasks in the Process editor, Design Studio simultaneously builds in the background the corresponding artifacts necessary for deployment to the OSM system.
You can use the diagrammed representations that you design in the Process editor to illuminate patterns and identify inefficiencies in processes. Process editor shapes, colors, and presentation can communicate information about the flows and processes.
Related Topics
