Task Editor Redo Tab
The Task editor Redo tab appears for activation task types.
Use the Redo tab to define part of your compensation strategy for activation tasks: to redo tasks that are affected by amendments. Complete the compensation strategy for activation tasks on the Undo tab. See "Task Editor Undo Tab" for more information.
Field | Use |
Compensation Strategy |
Specify the compensation strategy to redo a task when it is affected by an amendment:
Use existing request mapping |
When Compensation Strategy is set to Redo (new order), the Redo operation uses the same request mapping settings as the original order. |
Re-configure request mapping |
When Compensation Strategy is set to Redo (new order), you can specify new request mapping settings for the Redo operation. The Task Data area and Service Actions area behave as they do on the Request Data tab. See "Task Editor Request Data Tab" for more information. |
