Properties View Compensation Tab
Use the Properties view Compensation tab to define the execution modes that automation plug-in can process. This tab appears only for Automator and Sender plug-in types defined as an Internal Event Receiver.
Field | Use |
Execution Mode |
Specify the execution modes that this plug-in can run when invoked. For more information about execution modes, see "About Task Compensation." Select one of the following execution modes from the Normal column for execution modes that occur when the task is processing normally:
Select one of the following execution modes from the Fallout column for execution modes that occur when the task has failed:
Note: Design Studio has validations in place that prevent you from defining more than one internal event receiver automation with the same execution mode per automated task or automated notification. For example, an automated task can not define two internal event receiver automations that both have Do selected for the execution mode. However, an automated task can define three internal event receiver automations if each defines a different execution mode (Do, Redo, and Undo). |
