Constraint Behavior Properties View Message Tab
Use the Properties view Message tab to define the language, content, and severity level of the message. For data element level Constraint behaviors, the severity level, in conjunction with the task status severity level, affects whether or not the task is allowed to transition.
Field | Use |
Language |
Select the display language for the message. |
Message |
Enter one or more messages to display when a condition is not satisfied. |
Display as |
Select the severity level as follows:
