Information Behavior Properties View Help Tab
On the Properties view Help tab, you can create context-sensitive, online help in the web client by selecting a language and defining the help topic and text.
Field | Use |
Language |
You can declare Information behaviors specific to a given language by using the optional Language attribute. If this attribute is set, OSM automatically selects the appropriate instance using the user's language preferences set in the web browser. |
Topic |
Enter the topic name for this help message. |
Message |
Enter the help documentation that will be displayed in the web client when the user clicks the associated field Help button. Note: Use valid HTML to enter the help message. |
